Thanks for the comments. It was a blast to build. My wife said she didn't mind so much cause it kept me from getting into trouble with other things. She can keep an eye on me in the garage.
White sidecovers were definitely considered and still are. I have plenty of paint left. It always had white sidecovers in my minds eye but when I put the tank on, I kinda liked the balance.
I still may do it soon .
The oil gauge is on the wish list. I may just get over to a supply place in Houston and pick up the parts. My bro, KGhost, made an adapter for me to mount it so the hard part is done.
The engine is the '78 part of the equation and had about 17,000 miles on it. I never got into it further than new gaskets under the polished covers. Hopefully it will hold up for a time while I get started on the next one. The thing purrs nicely but I will listen carefully for any changes. The fluids will be monitored very closely.
The tire is pretty fat. It is a BatteAxe that is mounted on alloy rims from a '76 CB750A. I found that the CB750A rims did take a wider tire than stock. Beware-If you find a set of these, makes sure you grab the swingarm with them. The swingarm is wider also and makes thing so much easier when putting these on the bike. I used a needle bearing setup on the swingarm and I am really looking forward to seeing how this works out.
The tank has just been lined prior to painting so no crud is in there but I still think filters are a good idea. I plan on picking up one this weekend.
The decals are from Carpy. He has always been so cool. I can't even imagine how hard this guy must work everyday to turn out the works of art he does. Especially considering it took me a year to do mine. He was the inspiration for this project. If I hadn't stumbled across his site, this bike would still be sitting behind a shed under a rotted tarp where it sat for 16 years. I really appreciate his motivation and occasional emails making sure I was doing OK with the project.
There are a lot of people on this forum who have helped me.. Like I said, this was my first bike to rebuild and I would have given up long ago without guidance from this site.
Many thanks and I will let you know how things go.
