Hello! After changing oil, filter and cleaning the pan the kick feels different, feels jerky and dry ish.. I have kicked it over many times and used the starter to make sure oil has had time to circulate. I think its quite some time since the oil was changed last time. When using the starter and trying to start some smoke is coming out of the pipe.
Have not been able to start after the change. If I open the chocke fully and hold the throttle fully open it will start, but dies immediately.
Gas has also been spotted on the sparkplug and in the oil and black plugs.
Going to change the float valves to new 2.5 ones I just ordered for 80$ since I suspect the aftermarket ones may be leaking.
The bike was not running perfectly before this.. The idle was not good, but it was running great when riding.
Checked the spark on the plugs and the spark seemed to be all over the place. Going to switch from the NGK iridium my old denso U, tho I understand this won't help much. Also have NGK caps with resistors built-in.
Sent fra min E5823 via Tapatalk
