Author Topic: Anyone ever replace an oil pressure switch cb750, engine in frame? What a PITA!  (Read 839 times)
Offline markb
  • When I finish my current project I might be a
I'm not actually replacing it but I'm trying to hook up the wire. With the engine in the frame and the carbs in it's almost impossible to get at the screw to tighten down the terminal.  >:( I just put a battery in and was checking out the wiring and my oil pressure light didn't come on so I found the the wire was disconnected at the switch. Maybe pulled it out while working on the engine. Maybe just for forgot to hook it up. Who knows? Thought I'd throw up a post while I was taking a break from it.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline beemerbum
Cam   chain tensioner with carbs in place aint no picnic either
The one beside the tensioner, use a stubby screwdriver, or a  1/4 inch screwdriver bit, taped to a 1/4 inch wrench.
To get them out, if you will replace screw, alligator visegrips.
 Hope the middle does not turn or leak.
Offline markb
...use a stubby screwdriver...
Yes, real stubby.  :D
