I'm having an issue with the wiring for my motorcycle, its a cb650sc 1982. I took a lot of the components off and after putting everything back together im finding that with the ignition turned on the rear turn signals aren't always on like the front ones are, but the turn signal switch does turn it on and off as usual. I took a look at the flasher unit and found there to be 3 wires, and only two of them would get the lights to flash. My second question is, there are only 2 wires that make this turn on, whats the third green wire used for? I'm also having problems with the brake light being turned on from either brake switches, both switches are good. I'm guessing I have the wrong wires placed on this flasher and may be causing issues on the brake light end of things.
Any help is appreciated, hope everyone had a good weekend!
