Author Topic: 1974 CB550 rear disc conversion  (Read 1704 times)
Offline Peekster
  • you are probably underestimating me
« on: April 15, 2019, 02:44:52 PM »
Dose anyone know a good way to convert the rear brake to disks? I also want to convert to hydraulic to work better with a new set of rear-sets.
1974 CB550
Modifying custom parts
Offline Bankerdanny
  • Endeavor to persevere
Re: 1974 CB550 rear disc conversion
« Reply #1 on: April 15, 2019, 02:55:48 PM »
If you are staying with wire wheels you can adapt the setup from the 75-76 CB750F. Another option is a drum-to-disk conversion kit sold by CycleX, but it isn't cheap.
In the past I have looked at the stock alloy wheels from a Honda FT500 Ascot single. It is chain drive on the left with an 18" rear disk brake wheel and a 19" front with a single disk on the left.
Offline Peekster
« Reply #2 on: April 15, 2019, 05:34:20 PM »
Thanks guys. Ill look into the CB750 conversion, is it a simply swapping wheels?
1974 CB550
Offline sparks1
