Well what a day I had Sunday. Woke up early, cooked me some vittles (I've no idea what "Vittles" are, but I know that a "Vittler" is an old term for a military person who sources food, so I'm guessing that "Vittles" are food) before my big day in the driveway began.
Terry's brekky 4 May 2019 by
Terry Prendergast, on Flickr
Okay, protein in, coffee swallowed, and out to the driveway, and the ol' Swamp Rat. Being the careful motorcycle technician that I like to think I am (but know I'm not) I decided to drop the ol' sump pan just in case there was a little bit of sludge to remove. There was, lots...........
Swamp Rat Sunday 12 May 2019 5 by
Of course, there was a little sludge build up on the pump as well...........
Swamp Rat Sunday 12 May 2019 4 by
Did I say a little? That's like saying I like to drink a little bit. Anyway, I started to clean out all the sludge, and found this. Bugger.
Swamp Rat Sunday 12 May 2019 6 by
Swamp Rat Sunday 12 May 2019 9b by
OK, so I went looking for a better sump pan. I found this one, but sadly the thread for the sump plug was stripped, and I didn't have a 12mm coarse thread helicoil kit, so I had to think of an alternative plan.
Swamp Rat Sunday 12 May 2019 8 by
Good old JB Weld. Of course, I needed it right away, so I first cleaned the damaged area on the outside, then splooged some in, so there was a nice deep puddle of the magic gloop.
Swamp Rat Sunday 12 May 2019 9c by
Anyway, so as not to bore your pants off I won't post a pic of me cleaning and reinstalling the oil pump and sump pan, but I did, and then it was time to find an oil tank and hoses. I was a bit worried that being a 1975 engine it would have the big engine breather tube at the back of the gearbox, but in fact it had the small one, so I just used one of the early oil tanks I have hanging in the garage, and a pair of good hoses that still had the alloy crush washers in them. The bottom hose fitting on the oil tank has been brazed back on, (maybe after a crash) but it was clean inside, and I blew the hoses out, and called it good.
Swamp Rat Sunday 12 May 2019 9d by
Swamp Rat Sunday 12 May 2019 9e by
OK, so what next? I know, some carbs! I didn't have any nice soft carb rubbers so I found four rock hard old #$%*ty ones, and dropped them into my "shed Kettle" and boiled the sh1t out of them until they were soft enough to fit to the head, then using Steve-O's "Fence Paling" method, levered the carbs into place.
Swamp Rat Sunday 12 May 2019 9g by
Sadly I broke my special tool in the process, so I'm gonna have to "borrow" another one from one of my neighbours fence thee next time I do this.
Swamp Rat Sunday 12 May 2019 9f by
OK, so I had an oil tank full of nice fresh oil, some carbs, an ignition with cleaned points, so what else did I need for smoke and fire? I know, coils and plug leads! Some d1ckhead (me) had cut the signal wires offa every old Honda coil in my garage to connect to Dyna coils from previous builds, so I had to chop a blue and yellow wire off an old wiring harness to fix them.
Swamp Rat Sunday 12 May 2019 9h by
I installed four crappy old plugs that I cleaned up a bit on my wire wheel, bolted in the coils, and by that time it was getting dark, so I called it good and gave it away for the day.
Swamp Rat Monday 13 May 2019 3 by
Last night, I had a little time after work, so I hooked up my little temporary fuel tank and an old car battery.
Swamp Rat Monday 13 May 2019 4 by
Swamp Rat Monday 13 May 2019 by
I cranked the engine by connecting the battery directly to the starter motor to check if I had spark and circulate some oil, and confirmed that I had spark. I filled the carbs with fuel, and fuel pissed out of two of them, and no amount of tapping the float bowls would stop the flow, so I dumped the fuel back into my can, and gave it a few kicks, as the battery had died again. I got a few pops, but nothing like a start, so gave it away for the night.
Tonight I had a closer look at the carbs, and realised that I'd missed something critical.
Swamp Rat Missing vacuum screws by
Yep, that'll do it. I raided another set of carbs, stole the screws, installed them, and kicked it in the guts, and guess what? It runs! Life is good!
Not only did it run, it ran on all 4 cylinders, and blew no smoke! I checked the oil tank and the level had dropped by approx 1 litre, so that told me (without having an oil pressure gauge to hook up) that the oil was circulating, but just to be safe, I shut it down. Anyhoo, 16 days ago I bought this thing for $500 ($350 USD) with a rusty seized engine, and now it has a sweet running engine.
Next step is to pull it out (the engine, you sicko's.........) strip off all the rotten rusty parts, send the frame out for blasting, paint it, and start putting it back together into some semblance of a motorcycle. I want to be riding this bike by the end of June, so I can crack on with my big Kawasaki's and my RC51. Wish me luck, I feel like this guy here looks right now!
Leo Monday 13 May 2019 by
