Author Topic: Big cam/ blue pipes question  (Read 2235 times)
« on: May 02, 2019, 07:16:53 pm »
 I've got a 70 750 with a K4 836 mildly ported. It also has a Kenny Harmon F cam, new stock valves, springs and ti retainers, the plugs look good, 4 cable carbs with 130 mains but the unknown origin header has a lot of blue on all four pipes, it had some when I got it used. I'm wondering if the long exhaust duration on the KH/F cam has much to do with the blue pipes.
 My concern now, is putting a stock 300 exhaust on the bike. I know they are somewhat shielded but I don't want those turning blue too.
 Thoughts?
Offline dragracer
  • CB750F Dragbike
Re: Big cam/ blue pipes question
« Reply #1 on: May 02, 2019, 08:51:26 pm »
Blued pipes are typically a sign of a very lean condition. The pipes blue from extreme heat.  This is a carb tuning issue. Rejetting the carbs properly would have saved the color on the exhaust.
Offline Tracksnblades1
« Reply #2 on: May 02, 2019, 09:12:38 pm »
 Thoughts?
Chrome blues at surface temperatures around 900*. Keep all that gas burning in cylinder instead of in the pipe. Quit mixing Nitromethane in it. It burns all the way out the pipe. 😎 High performance naturally aspirated engines can have EGT's over 1000*. Reputable tuners write, as I believe, the spark plug is the best thermocouple used to determine cylinder temperatures on high performing engines. The only headers mounted on a high performance engine that I've never seen turn red at sustained wide open throttle were on a boat engine. Turn the exhaust water injectors off and they would too.  Good luck...and share your secret..😇
« Last Edit: May 02, 2019, 09:31:25 pm by Tracksnblades1 »
Age Quod Agis
« Reply #3 on: May 02, 2019, 11:43:22 pm »
 I'm thinking I preferred the F2 cam that was in it before anyway, I don't get this bike into the rpm's this one needs to work, I read it has a lot of overlap and exhaust duration for valve cooling when road racing. The bike's due for a diecast motor at some point but I can't wait for that to run the stock pipes.
 Maybe it's a good time to mount the O2 sensor I got for a contingency prize last year.
« Last Edit: May 02, 2019, 11:44:55 pm by Don R »
« Reply #4 on: May 03, 2019, 02:57:12 am »
Why not a DP295 cam? Or RC ;)
« Reply #5 on: May 03, 2019, 05:16:46 am »
Mildly Wild Ported Head...?
I don't think you need O2 sensor to tell you what you already know...🤓
« Last Edit: May 03, 2019, 05:25:36 am by Tracksnblades1 »
Age Quod Agis
« Reply #6 on: May 04, 2019, 07:29:28 am »
Only because I have the F cam. There's an RC 327 in the tool box but that's about as radical as the one I have now. I agree a smaller performance cam makes sense. I know they don't make gobs of torque no matter what I do cam wise but moving the rpm range down to where I ride is a better idea.
 It's not ported huge, I just clean them up under the valve, around the guide and smooth the inside radius a little.
 It's got one cylinder fat this morning. It insists on leaking through after multiple new floats and valves. Starting to concern me. There's a reason one pipe is blue.
« Last Edit: May 04, 2019, 08:02:40 am by Don R »
« Reply #7 on: May 04, 2019, 11:13:34 am »
Wouldn't the increased overlap allow fresh air/fuel mixture to enter exhaust pipes thus aiding in cooling until the cam was operated in its effective tuned rpm range...?   👀  Provided exhaust has no leaks.
Age Quod Agis
« Reply #8 on: May 04, 2019, 03:37:51 pm »
 This may be true, the cam was supposedly ground for road racing and keeping the exhaust valves cooler.
« Reply #9 on: May 04, 2019, 07:08:59 pm »
Most of the 'hot' cams for the 750 have lots of overlap time. This ends up pulling unburned fuel thru the chamber(s) quite a bit at lower engine speeds. If the spark timing is delayed somewhat, it will help to fix this up by not lighting off the unburned fuel quite as readily: it will then tend to burn up toward the carbs instead, where it gets extinguished by the next intake stroke. The 'down' side to this is the switch-like feeling of power coming on when this back-burn meets the intake timing: otherwise known as the 'roadracer's surge'. A side-effect on real wide-duration cams is the "GP pop" that you can hear on the old movies of guys like Hailwood, et al, when engine-braking into turns.
In the 750, though, you have an 'edge' to deal with this in the form of the Keihin carbs. You can install a leaner idle jet (#35 or #37.5) to reduce the overfueling. Doing both this and slowing the spark curve helps a lot. ;)
  • Moderator
« Reply #10 on: May 08, 2019, 05:59:23 am »
It sounds like you need the DP295 cam Don, it gives a much better spread of power right through the rev range.
« Reply #11 on: May 08, 2019, 08:24:58 am »
 That's what's in the back of my mind Sam, I was playing with this one because it was in my brothers tool box and I traded parts for it.
