Hi, this is not a stock wiring harness, but modeled after it. It's for a 78 CB550K. First time wiring a bike up.
I hooked up the battery, flip the switch, running light pops on. I push down the brake pedal and the fuse light goes red. I look at the 5 amp fuse looks ok but I get 10 amp same thing happens. I pop in a 15 just because and I unhook the spring at the brake connector (see below). I pull the stop switch with pliers and fuse goes out.
Now I look at the wiring. The brake light has three wires black(ground),red(running) and Yellow(brake). I tested the red and yellow earlier and the yellow made the bulb shine a bit brighter so I determined that it was stop.
At the switch it's stock colors so black to switched power and green/yellow to a 3 way junction consisting of another green/yellow to front and to yellow to the bulb.
What's going on?
