Author Topic: Headlight issue  (Read 1483 times)
Offline luwys
Headlight issue
« on: May 28, 2019, 02:08:03 am »
Hey guys I hope someone can help me out I have a Honda cb750k as my commuter no issues but the other day while I was warming it up I noticed my headlight went out I flip the high beam / low beam switch and was not even getting the indicator light on my dash ... does anyone have any suggestions I need to get to work
Offline jaytee-nz
Re: Headlight issue
« Reply #1 on: May 28, 2019, 03:24:56 pm »
My suggestion is to ask this question in the right section of the forum.
Offline DarkLinkX5
Re: Headlight issue
« Reply #2 on: September 04, 2019, 04:39:18 am »
also try cleaning switch contacts. they get corroded which adds a ton of resistance after sitting for so long.
take it apart slowly so you remember where the small parts go plus it may have springs or BB's for the snap effect.
if the switch isn't making contact lights wont turn on.
1977 Honda CB550k
Offline CBFalcon
Re: Headlight issue
« Reply #3 on: October 18, 2020, 06:01:54 pm »
Had the same problem the other day..  ended up removing the headlight and putting it back together and it started working again, although Im worried it ain't gonna be that easy..  posting incase you come up with a solution
