OK guys, the person behind this project is called Garth Allison and this is his last post, copy and pasted from Facebook.
Garth Allison Sam Green sorry can't get tapatalk , but the vision behind this project is something I could build after my CX500 cafe racer that was as people said , " a cookie cutter " . So my thoughts went to CBX 1000 , and other Honda twins that use the top section of the motor as an engine mount . I will mildly modify the engine as my budget is small . I making it a track bike , hence no alternator / charging system . The cases are std ones which took hours to shape and the RSC logo is Bonded on using Devcon . The frame will be actually similar to the CX500 , but very MotoGuzzi like also , with billet side engine / swing arm plates . The substantial single back bone frame will also be the oil tank . I know people have their view on this concept , but the top mount I have worked out , the only worry I have is oil leakage / sealing around the base and head gaskets . Drew a quick drawing of want I have invisaged . This is purely a experiment in design , I may work , it my not , but hay ,want the heck 😃☹️🙏
