Hey all,
I recently acquired this old girl and the PO had taken most of it apart as part of a resto project, but lost interest. I have the factory harness, but replacement left and right hand controls (vintage 750.com) I have most of it together, but not having much luck getting lights to work. The taillight comes on in pos 2, and I get oil pressure and neutral lights in pos 1 (run), but no headlight or tail or turn or horn. Starter button turns over engine though. My question is, if the ignition switch is turned to pos 1, what fuses should be hot? This will give me a starting point.
Currently, I'm just getting voltage on the main.
Fuses are good, fuse holder looks good (no power on the backside of it either), new batt,
Thanks in advance
Kevin
PHX
