Hello all! I have an issue and I'd like to pick the your collective brain.
Bike: 1982 CB650SC Nighthawk
Modifications: Minimal. Handlebar replaced. Front fuse box relocated (temporary wrap in electrical tape)
Recent relevant maintenance: In the last 1,000 miles I have changed and gapped the spark plugs, adjusted the valves (x2), changed the oil, added a UNI foam air filter designed for the stock airbox. I have hooked the carbs up to a sync but they were spot in. I have never removed the carbs on this bike for the 4 years I have had it.
Other relevant information: There has been a right sided, top-end tick for ~8 months that increases with revs. It is not loud or harsh. I adjusted the valves repeatedly in order to make this go away and it did not. It feels to have full power and up until recently ran perfectly. My working diagnosis for this issue is a slight exhaust gasket leak.
The problem: It will only run on 1/4 cylinders (cylinder 4) without help. It needs choke and throttle to start and then quickly dies. Only the 4th exhaust header is warm the remaining three are cold.
Workup so far: I have checked for blown fuses, and unhooked ground wires and so far nothing. I have sprayed starter fluid in the airbox without the filter (3 starts for a total of about 6 squirts of fluid) and the bike with rev up to ~4k rpm then come down. It will run extremely rough with some throttle and dies immediately afterwards. At this point exhaust headers 1 and 2 are slightly warm, 3 is cold and 4 is hot. I recently filled up gas 9 miles ago at a local gas station and used 91 octane (I know >86 doesn't matter) ethanol free gas like I have for years. At this point I think I am being pointed to low fuel delivery caused gunked up carbs and bad gas. The bike leans left when parked so perhaps this lead to carbs 1-3 being gunked up by mislabeled ethanol gas more than carb 4. I would rather not tow the bike home (I have no truck or trailer). I may go back and pull the spark plugs but I'm not sure exactly what I would be looking for, and I have never had a plug foul on this bike. I just want to make sure I'm not missing anything before I pull the carbs for the first time.
Thanks for the help!
