If it's in the original location and the wires haven't been extended it's as simple as remove the gas tank, unplug the switch, swap them and reassemble in reverse. When you plug in the switch be sure to use some di-electric grease and pull the cover back so you can see if the male terminals push back out of the plug. I recently had that happen on an aftermarket wiring harness/switch.
