Author Topic: How do you remove points shaft from end of crank please  (Read 903 times)
Offline Scott
  • 72 CB750
« on: June 04, 2019, 07:02:39 PM »
G'day
I'm pulling apart a CB750 "parts engine" and I need the points shaft for a new crank I will be using in the new engine.
I don't want to damage the points shaft removing it.
Also what's the method of putting it into the new crank.
Thanks for your time
Scott
Offline DickL
  • Really really old
Re: How do you remove points shaft from end of crank please
« Reply #1 on: June 04, 2019, 07:28:10 PM »
Put two of the correct threaded nuts on the end of the points shaft.  Run them down some. Turn the inside one out while holding  the outside one with a wrench.
1970 CB750
1999 Honda Valkyrie
Offline Scott
  • 72 CB750
« Reply #2 on: June 04, 2019, 07:46:41 PM »
Thanks
Quite obvious now that you point it out.
I looked at the new crank and couldn’t see a thread in there and thought it was an interference fit, I guess I didn’t look too hard or think too hard.
It’s out now and not even damaged
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: June 04, 2019, 08:37:20 PM »
Replace the “O” ring.......
Offline Scott
  • 72 CB750
« Reply #4 on: June 04, 2019, 08:55:15 PM »
No worries
Offline Scott
  • 72 CB750
« Reply #5 on: June 04, 2019, 09:00:02 PM »
I’m still a little way off putting the 1000 cc engine together and making a list of bits and pieces that I will need.
Looks like I might need a different output shaft than the one from the spare parts engine also, so the list will probably keep growing b
« Reply #6 on: June 04, 2019, 09:08:52 PM »
Yamiya sells new, with o-ring. Not bent as old used ones might be.
http://www.yamiya750.com/index.php?main_page=product_info&cPath=246_21_250_55&products_id=2877
Offline Scott
  • 72 CB750
« Reply #7 on: June 04, 2019, 09:31:54 PM »
$40 aussie isn't too bad.
I see what else I can buy to make the postage worth while
Offline DickL
  • Really really old
« Reply #8 on: June 05, 2019, 03:38:57 AM »
Beware.
The repro shaft and oring leaked on my engine. Slinging oil everwhere out off,the shaft home. II replaced it with a,straight old one and leak went away.
1970 CB750
1999 Honda Valkyrie
Offline Scott
  • 72 CB750
« Reply #9 on: June 05, 2019, 11:29:18 AM »
Good info.
Thanks
