Author Topic: 73ish Cb750 won't idle and drinks way too much fuel  (Read 3002 times)
Offline OperatorAndy
« on: June 20, 2019, 09:29:50 AM »
Just finishing my project and it's looking great but.....the bike starts right up but will not idle and consumes a liter of fuel in 5 minutes of testing!
The carbs are the 657a round tops.
Pilot 40
Mains 105 (110 stock according to my research but I just have105s and 120s)
Needle at 4th from blunt end
Floats at 26mm
Static timing done
New points and condensers
4into1
Pods (on or off.... no change)
Compression of about 145-150 on all 4
Bench sync done (it won't run well enough to use my sync tool)
Static timing is bang on (won't run well enough for my timing light... that is, I have to have the revs at 1500 to 2000 to keep it running and I believe the timing advance is kicking in because I'm nowhere near the F mark)
BTW what is a good smooth idle rev?
This was a full engine rebuild as the case was cracked. Before the rebuild the bike would idle but that was it. It sat for years with the po and I went straight to the rebuild.
Any help would be great! I can take some pics if needed. Just for a laugh, I should take a video of the fuel consumption in the clear line. At the rate it's going, a tank would take me on a 15 minute ride.
Offline epheme
Re: 73ish Cb750 won't idle and drinks way too much fuel
« Reply #1 on: June 20, 2019, 10:04:51 AM »
it's got to be going somewhere. What are your AFM screws set at? If you can't see it leaking under the bike anywhere, check your spark plugs to see if it's burning exceedingly rich. My other guess would be somehow it could be getting into the oil, so I'd drain your oil and sniff for gas. Only other place I can think of is if it's going thru the head unburnt to the exhaust?
« Reply #2 on: June 20, 2019, 10:31:05 AM »
... just FYI,  I have also tried two sets of coils. The battery is new and I have a charger on it. This was to make sure that I was getting good spark of course.
« Last Edit: July 01, 2019, 07:42:37 PM by OperatorAndy »
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #3 on: June 20, 2019, 01:54:10 PM »
I would suspect one or more carbs are flooding, are all the headers getting hot?
In the UK anything over 40 years old only needs insurance and Fuel.
« Reply #4 on: June 20, 2019, 04:18:54 PM »
+1 definitely verify all four pipes are hot.....
Are your new points and condensers OEM Honda...?
Is it starting right up cold with choke or no choke...?
Are you sure you set both points on the peak of high cam...?
I would double check point gaps first. Improper adjusted points can masquerade as carb problems. if you have to change points any, it changes the timing. So you have to check points then check timing, if you move timing, it can change point gap. So then you have to check points again.... then timing...eventually you'll get both spot on....
PEWE has a post about tightening up these clearances so your not constantly double checking...
« Reply #5 on: June 20, 2019, 05:06:04 PM »
Backward carb slides?
Sorry, had to ask after I got a set of 657b round tops in for rebuild with all 4 slides in backward...I didn't even know they could fit until then!
« Reply #6 on: June 20, 2019, 05:50:17 PM »
Upside down....?
« Reply #7 on: June 20, 2019, 06:24:12 PM »
Upside down....?
Just rotated and switched between carbs, like someone took all 4 apart and then got the mirrored ones backward.
I did this once on my old SuperHawk, too. Plugs lasted 8 minutes, while I scratched my head (and wondered how it suddenly got so much low-end torque!). Took out 2 pairs of plugs before I smacked my forehead that day...but that was in my old pot-headed days...(at least, that's MY excuse.).
« Reply #8 on: June 20, 2019, 06:41:08 PM »
Upside down....?
I was stuck on the slide orientation pin. I hadn't considered right to left or left to right....
« Reply #9 on: June 21, 2019, 02:16:36 AM »
Carb slides were wrong, bike runs OK now?
Offline disco
« Reply #10 on: June 21, 2019, 02:18:21 AM »
+2 probably fouling plugs rapidly as well?
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
« Reply #11 on: June 21, 2019, 06:52:02 AM »
Thanks for all the replies! I'll check the pipes today. I can also color tune the cylinders as I have for the number 1 and 4 (2 and 3 will be a pain). So left to right slide swap eh? I never thought of that. The fuel is not going in the oil... that was my first thought too. Plugs are getting quite fouled! You would to if I poured that much fuel on you!  :D I don't think the carbs are flooding... new valves and seats and she holds fuel when shut off. Any thought though on a good idle speed for day to day? Also, rpm for setting timing? I may not get back to the bike for a day or two. Work gets in the way of a good hobby!
« Last Edit: July 01, 2019, 07:44:32 PM by OperatorAndy »
« Reply #12 on: June 21, 2019, 09:22:57 AM »
I had a chance to pop the carbs off and check a few things... slides only go in one way in these carbs... for sure. To answer a few of the questions, the afm screws are now at about a half turn open but I've tried all sorts of positions, still haven't checked the pipe temp as I have the carbs off now, points gap is at 13 as per spec. I've now attempted setting timing with a timing gun but I read that I should have the rpm set to 900 to 1000 for this... the engine doesn't like that low speed. I was getting a lot of exces arcing on the 1-4 point so I changed the condenser back to the old one and it went away (very minimal sparking is expected right?). I should say that I first swapped it to the 2-3 point and the arcing moved too. New condenser is made in Japan and has Daichi stamped on it.  Now to put the carbs back on and check temps.
« Reply #13 on: June 21, 2019, 09:31:15 AM »
Btw... I need to use the choke to start it up cold. And I set the points gap at max opening.
« Reply #14 on: June 21, 2019, 03:03:39 PM »
Slides can go in 2 ways (right & backwards).......As Hondaman has indicated Mirrored Carbs can swap slides effectively allowing the cutaway part of the slide to face the wrong way. Carbs 1&2 have the slide orientation pins and the adjustment screws on the left side. The mirror image carbs 3&4 have their slide pins and adjustment screws on the right side.  As you read HondaMan's post, he indicated the 657b carbs he recently rebuilt had the slides reversed, not believing or knowing that was possible....
If you're not picturing this mentally, take a picture of the slides from the air cleaner side and engine side and post them....
You can check your initial (static) timing without starting it...
Did it idle @ 900-1000 rpm before rebuilding...?
Stock camshaft..?
« Last Edit: June 21, 2019, 05:06:32 PM by Tracksnblades1 »
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #15 on: June 21, 2019, 03:12:56 PM »
Carbs bench synced? Idle can be all over the place if you didnt
« Reply #16 on: June 21, 2019, 06:09:19 PM »
The points gap should be at 0.014" and this should meet the "F" mark (when you can run it long enough to use a timing light on it) at 1000 RPM. If the points are Daiichi points, you will play the devil to get this to happen, and it may not at all in the end. Most of the time the Daiichi points end up advanced, which causes lots of troubles...
...and the Daiichi condensors are famous for being bad right out of the box...
If the spark timing is too advanced, this causes spitback at the carbs, which makes them run very rich because the engine is ruining the fuel flow with this activity, making the carbs act like the engine is running slower than it really is. The carbs mix richer as engine speed slows down, by design.
« Reply #17 on: June 24, 2019, 07:41:36 AM »
Stock camshaft..?
All of the carb slide pins are on the right hand side. I'll post a pic this afternoon. I didn't have to picture it mentally,  I pulled them out and looked.
I have done static timing .... bang on. The gap I have listed as 0.012 to 0.014 and I'm there.
I only started it up a couple times before the rebuild started a few years ago. It ran poorly but had been sitting a long time before that. I have no idea if this was a stock cam shafts. I wasn't going to do an engine rebild until I cleaned the engine and found that the chain had punched through the case.
I was told to check that all cylinder's are hot and they are. After bench syncing the carbs , I did have to lower the idle.
I just can't wrap my head around how,  with all of the recommended cab settings that I posted as a starting point ,  can this bike draw that much fuel into the engine that fast?  It was probably over 2 years ago that I dropped the cam shaft in... please tell me it only goes in one way. ???
Thanks for the suggestions so far... thanks hondaman. I'll swap the original points back in and give that a go. 1000rpm is hard to achieve and it's no good setting dynamic timing when she's running poorly.   I will double check the points gaps and static timing again.... light out at the f marks...
« Last Edit: June 24, 2019, 07:59:19 AM by OperatorAndy »
« Reply #18 on: June 24, 2019, 08:28:56 AM »
I haven't taken the time to introduce myself and with all of the help I'm getting, I though it was about time. I crossed the 40 line a while ago and have been working on bikes for about half of that. I started riding with a little 1972 ATC70 that I restored a few years ago including powder coating (free from a friend) and reproduction factory flames! That is still everyone's favorite machine in the garage! I have a little 400cc Suzuki that I cafe'd a while ago and I have won a couple of best in show awards at our little show in town. That bike runs and sounds as good as it looks.... not too comfortable though lol. I live in Canada on Lake Huron. Last summer I bought a used Vulcan 900 and made a trip to the salt flats for speed week. That was amazing... dying to go back! About half way home my stator fried. I ended up in Iowa City in an abandoned parking lot in the poring rain swapping it out with a new one with just the tools in the factory kit plus one Alan key borrowed from the shop that sold me the stator. It's funny, but looking back, that may have been the best part of the trip! One other trip of a life time was taking my little Super Sherpa enduro down the the Hatfield and McCoy trails in WV for a week. Nice trials, nice folks and cheep beer. Only had to replace a tube on that trip.
My formal education is in Physics and Computer Science. I teach at the local high school. Engines are my hobby... bikes, boats, snowmobiles, etc.
Keep the ideas coming... if you're ever riding through, the fridge is alway stocked!
« Reply #19 on: June 24, 2019, 09:54:49 PM »
My round tops are 069a. Now it's what killed the cat. I'll have to take mine off now so I can get a mental picture of it. ???????
« Reply #20 on: June 25, 2019, 03:12:34 AM »
Enough to remove air filter and make sure that choke is not blocking the view
Bottom of the slides have a small gap facing outwards so air can enter easier on lower lift. No gap,when slide is mounted wrong. The gap then visible from engine side
https://www.ebay.com/itm/293111665441
« Reply #21 on: June 26, 2019, 07:01:44 PM »
Here are the pic's as promised.  As you can see, all of the slots and pins are on the right side. The other pic shows the stamping just to be sure. I also tried to run her with the 1977 carbs after a quick clean... no change... still drinks a liter every 3 or 4 minutes,  but tbh... a quick clean did not quite do the trick either. Back to the drawing board.
« Reply #22 on: June 27, 2019, 05:14:54 AM »
 Tell us that clear line in your picture is just some vent lines and not where your hooking up your gas lines.
Offline Sigop
« Reply #23 on: June 27, 2019, 02:15:28 PM »
+1
CB750 K3  Original Owner and Operator
« Reply #24 on: June 27, 2019, 07:54:05 PM »
Yes... old small lines are carb vents... but the way this thing runs... good suggestion!
I had a chance to do a few things last night.  I swapped the timing advance plate out. The locator pin was falling out! I also redid the valve gaps and found I was way out... I don't know how I made that mistake... bad source for info? In= 0.002 and out=0.003? But I was way more then either of those.  I closed it all up and gave it another try. I only ran it for a couple minutes as I'm out of fuel at home... but it idled WELL! It still uses too much gas to be ridable but I can now time this properly and sync carbs and color tune.  That may be after my big home move, but I'll let you know how things go. For anyone reading this looking for help, a few of the other good suggestions that I was given were to weigh the cab floats...my plastic floats were 10 to 11 grams, boil the carbs in hot water... I didn't try this, watch the fuel travel through a section of clear line and time it's consumption so that you'll have a comparison after making changes... I can do this now that I have a steady idle, old jets may be drilled by po. .. mine are new jets.
