Before you go tweaking on carbs, Do the complete routine 3000 mile tune -up. Establish that baseline first.
The spark plugs *should* be light tan. But, you are assessing mixtures for all throttle settings. What if mid range rich, WOT lean and idle lean.
If you are going to do anything other than cleaning jets, "read" plugs after running under load at a specific throttle setting. You have mechanically actuated slides, not CV or computer fuel injection.
Another thing to check is if the choke knob really fully closes the choke plates. Starts better if they do.
Please explain "lean popping".
