Author Topic: Why is this sprocket and washer not wanting to line up  (Read 527 times)
Offline messeduptriple
« on: June 29, 2019, 06:05:34 PM »
I'm having a weird time getting this to line up again...why is this not wanting to line up?
Sent from my PH-1 using Tapatalk
Offline BenelliSEI
  • 1969 cb750
Re: Why is this sprocket and washer not wanting to line up
« Reply #1 on: June 29, 2019, 06:20:53 PM »
There is a slot machines around the circumference of the shaft. The plate must be in it to rotate so the boltholes line up. The sprocket should slide in and out on the shaft so you can get the washer in far enough.
« Reply #2 on: June 29, 2019, 06:24:37 PM »
Thank you ...I will try that.
-Cristian
« Reply #3 on: June 29, 2019, 07:11:39 PM »
 Yep - the sprockets not on far enough. The plate should spin in the groove to easily align those bolts.
