Author Topic: What Jetting do I need? CB350F  (Read 9712 times)
Re: What Jetting do I need? CB350F
« Reply #25 on: December 11, 2012, 12:33:10 PM »
you'll need to remedy your airbox cracks and vacuum leak(s) BEFORE any jetting changes, or you're chasing your tail.
Offline jstfkndi
« Reply #26 on: December 13, 2012, 07:27:57 AM »
Ok, thanks. I was told WD40 as a leak tester. Any thoughts on this as I don't feel comfortable sprying carb cleaner on already dry boots.
« Reply #27 on: December 13, 2012, 08:05:53 AM »
+1
spray and listen for RPM change
Offline Owned
    • Finished Product
« Reply #28 on: December 13, 2012, 03:43:25 PM »
I vote for checking valves....
'01 Ducati 900ssie
'74 Honda CB350F
http://www.flickr.com/photos/indyrider/sets/72157619944545142/show/
'73 Honda CB350/400F Hybrid
http://s1231.photobucket.com/albums/ee520/indyrider2/?albumview=slideshow
'64 Honda CB160 Soon to be unveiled!
Offline jstfkndi
« Reply #29 on: December 14, 2012, 06:03:29 AM »
I adjusted them, but can recheck. Is that what you are referring to, or pulling the head?
Offline tomkimberly
« Reply #30 on: December 15, 2012, 06:59:16 PM »
FWIW, I set the valve clearance at .003", a bit on the loose side.
Tom
Offline WhiskeyFoxTits
« Reply #31 on: July 02, 2019, 07:07:38 PM »
I'm building a brat style CB350 four, and I want to put pods on my carbs and I know that I need to change my jets. Where can I find jets that would work with my bike?
Offline WhyNot2
  • I'm finally an
« Reply #32 on: July 03, 2019, 05:12:33 AM »
I'm in the same boat with my CB350F, cept I have a new Delkevic 4 into 1 exhaust.
Can't get it to run right, and pulling the carbs so many times is a pain.
So watching and trying everything you are, and with no good results,
