Author Topic: Drive Chain Rubbing  (Read 1233 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
Drive Chain Rubbing
« on: July 11, 2019, 12:54:10 AM »
While checking over the bike at teh end of yesterday’s run, I noticed this pattern on the chain. It is just the grease that’s come off, there is no metal removal - yet.
Anyone got any thoughts on what ot might be rubbing against? I don’t really want to start taking covers off to try to locate it.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline Erny
Re: Drive Chain Rubbing
« Reply #1 on: July 11, 2019, 02:51:09 AM »
From picture it looks as right side of chain, check area around front sprocket if it is not rubbing against case
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Kevin D
  • SE Michigan
« Reply #2 on: July 11, 2019, 04:15:19 AM »
Is the chainguard secure? My own hi mile bike busted the rear mounting tab on the swing arm and the chainguard brace got sliced in two from rubbing. The front chainguard mount held it in place. This part is shown on the K2 fiche but not listed. You may also have the case protector near the front sprocket.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #3 on: July 11, 2019, 04:26:15 AM »
 Pretty quick and easy to pop off the countershaft sprocket cover to see if there is any signs of rubbing there like witness marks in the crud and if not work downstream around the chainguard/swingarm/centerstand area.
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #4 on: July 11, 2019, 11:15:31 AM »
The tight curve to the marks suggests something in the vicinity of the front sprocket, it's a tighter radius than the rear.
In the UK anything over 40 years old only needs insurance and Fuel.
Online bryanj
« Reply #5 on: July 11, 2019, 12:57:28 PM »
That chain and sproket look orrible and worn to me
Offline jaytee-nz
« Reply #6 on: July 11, 2019, 02:40:07 PM »
Check your lower shock mount bolt - if it's too long it could touch the chain as the shock compresses.
Offline Kevin D
  • SE Michigan
« Reply #7 on: July 11, 2019, 06:55:41 PM »
+1 good eye on that Mark M
...and good on you Loner and best wishes for a safe and complete trip.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #8 on: July 11, 2019, 07:31:29 PM »
Check for a bent chain guard at or near the engine end of it. It might also be a too-long 6mm bolt there that holds the chainguard onto the swingarm.
