Author Topic: Rehabbing my original wiring harness..  (Read 1417 times)
« on: July 10, 2019, 10:15:13 am »
Does anyone sell a similar non-adhesive wiring harness wrap that is as nice as the oem?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Rehabbing my original wiring harness..
« Reply #1 on: July 10, 2019, 05:45:12 pm »
I used this on my most recent harness refurb:
https://www.amazon.com/gp/product/B06Y2KDQRN/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
It is more glossy than the original wrap, but the original may have been dulled by 40 years of exposure. No gooey/sticky adhesive to deal with, just plain wrap.
I used a wrap or two of this at the ends to hold it in place:
https://www.amazon.com/gp/product/B00HWRO744/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
TAMTF...
Wilbur
Projects:
                                           http://oldmanhonda.com/MC/wiring750K1.html
Sent from my Tandy TRS-80!
« Reply #2 on: July 10, 2019, 08:01:40 pm »
Has it held up ok for you in the Fl heat for a few years? The bike I will be using it on will be parked outside 24/7 in the CA heat.I have tried using just adhesive electrical tape but it will lose it's stickiness after a while and begin unraveling.
That factory tape is nice,and the way they wrap it.. real tough to match  ;)
« Reply #3 on: July 11, 2019, 04:48:26 am »
So far so good. I've used standard electrical tape in the past and the sticky goo it leaves behind is a mess. The wrap I linked to above worked really well and does not have any sticky adhesive to deal with. Had to do some soul searching to spend nine dollars on a roll of tape, but I'm glad I did. The second link is a silicone tape that actually fuses to itself and also seems to be holding up better than plain electrical tape for terminating the ends of the wrap.
TAMTF...
Wilbur
Projects:
Offline 574hondarider
« Reply #4 on: December 06, 2019, 05:55:43 am »
I know this is an old post, but do you remove the old wire harness wrap/sheathing first, or just go over it with this stuff?  This is my first time restoring a wiring harness.  Mine is in fairly good condition for its age '73.  Thanks!
« Reply #5 on: January 11, 2020, 07:13:00 pm »
I remove the old stuff first and go all new
