SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
I need a 17” comstar for my ‘80 cb650 any compatible wheels?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: I need a 17” comstar for my ‘80 cb650 any compatible wheels? (Read 953 times)
Easyskankin
Full Member
on:
July 12, 2019, 06:47:27 AM »
I have a 1980 cb650 I use as adventure/street scrambler I am having great difficulty finding a dual purpose tire in 16”. If I could use a 17” rear wheel I could easily find a rear tire. I need to know what wheels will work and if there’s a comstar 17” that would be ideal. Thanks
Logged
Bankerdanny
Eventually I will be old enough in reality to be
Really Old Timer ...
Endeavor to persevere
Re: I need a 17” comstar for my ‘80 cb650 any compatible wheels?
Reply #1 on:
July 12, 2019, 08:38:42 AM »
Quite a lot of late '70's Hondas used a 17" Comstar in the back. The CB750 Hondamatic for example. If you can find one of those it should bolt up, although you will probably need to make spacers to get it to work right.
Logged
Current: '76 CB750F. Previous: '75 CB550F, 2007 Yamaha Vino 125 Scooter, '75 Harley FXE Superglide, '77 GL1000, '77 CB550k, '68 Suzuki K10 80, '68 Yamaha YR2, '69 BMW R69S, '71 Honda SL175, '02 Royal Enfield Bullet 500, '89 Yamaha FJ1200
Don R
My Sandcast is a
Saver of unloved motorcycles.
Reply #2 on:
July 12, 2019, 08:44:18 AM »
Get it with the brake and cush drive to simplify things. I'd also look at twin cam wheels since your 650 ventured into that era. Drum rear correct?
Logged
Bankerdanny
Reply #3 on:
July 12, 2019, 09:21:05 AM »
For an adventure/scrambler build I would actually try and source a complete set from a 76-77 750A, which used spoked wheels with aluminum rims. These would look much more correct with this kind of build and weigh a fair bit less than a Comstar.
Logged
Easyskankin
Full Member
Reply #4 on:
July 18, 2019, 03:45:29 PM »
Thank you guys very much you have made this so easy. I will definitely consider the spokes!!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
