Author Topic: Yamiya CB750 New Tank/Fuel Cap and HOW to store OLD fuel tank  (Read 2225 times)
Honda3
Im swapping over from the grey blue tank I have (seen below) to the silver tank from Yamiya. Ive been told there arent many silver 1972 CB750s in the USA as they were only released in Japan.
My question is, I bought the fuel cap with the locking mechanic (with a key). Do I need any special tools to install it on the gas tank properly?
And whats the best way to store the old tank to prevent rust?
« Last Edit: July 13, 2019, 08:02:59 AM by Honda3 »
Offline lafindufondu
Re: CB750 New Fuel Tank and Badge Set and Fuel Cap
« Reply #1 on: July 13, 2019, 06:15:12 AM »
No special tools are needed.  Just need to make sure you have the small parts in order.
Honda3
« Reply #2 on: July 13, 2019, 08:00:56 AM »
Thanks,
What the best way to store the old take? I mean once i get the fuel out of it.
Re: Yamiya CB750 New Tank/Fuel Cap and HOW to store OLD fuel tank
« Reply #3 on: July 13, 2019, 09:40:03 AM »
I coat the interior with marvel mystery oil and just store it my garage.
Offline Scott S
« Reply #4 on: July 13, 2019, 09:47:54 AM »
 Some fuel caps/locks are held in place with a rivet and the end of the rivet has been "rolled". You have to carefully drill out the mushroomed end so that you can remove the rivet. 90% of the time, they're no longer reusable.
 Some caps/locks use a long screw and a nut. Those are easy and reusable.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline beemerbum
« Reply #5 on: July 13, 2019, 10:00:24 AM »
Hondaman sells a fuel cap screw kit for a very reasonable price. Check his website
Honda3
« Reply #6 on: July 13, 2019, 06:03:13 PM »
I already ordered a new fuel cap, and lock, petcock, petcock hardware and screen and washer set from Vintage750.com last night.
See here:
« Last Edit: July 13, 2019, 06:06:32 PM by Honda3 »
Honda3
« Reply #7 on: July 13, 2019, 06:07:48 PM »
Thanks Scott.
Im not swapping the gas cap from the old to the new. I bought a new cap and lock seen here, from vintage750.com
Offline Scott S
« Reply #8 on: July 13, 2019, 06:27:50 PM »
 Most of the locks I've seen use a screw to attach. Did it say anything in the description about hardware included?
 You'll still need a screw or rivet for the front of the gas cap, too. That's what beemerbum was referring to; the hardware Hondaman sells.
'71 CB500 K0
'81 Yamaha XS650
Honda3
« Reply #9 on: July 13, 2019, 06:58:01 PM »
OK I found it.
http://sohc4shop.com/catalog/product_info.php?cPath=25&products_id=38
So what ALL the parts I need to affix this to the tank:
« Last Edit: July 13, 2019, 07:00:48 PM by Honda3 »
« Reply #10 on: July 13, 2019, 11:55:52 PM »
If fuel cap is aftermarket, check the gasket so it does not cover the ventilation hole. I use DSS aftermarket complete fuel cap on my K2. Parked with warm engine and tank almost full.
 Tank suddenly got a huge underpressure day after so I understood the vent was blocked. Replaced gasket with Honda stock gasket and it solved it.
I could have fixed the gasket by cutting it on inside around 1mm. It has a flange on inside, thinner than outside that seal against tank, important to mount it right.
 It was too wide covering the vent hole. I blew the vent hole with compressed air and heard the wide gasket flabber in the wind
« Last Edit: July 15, 2019, 03:11:53 AM by PeWe »
Offline Scott S
« Reply #11 on: July 14, 2019, 03:37:57 AM »
 Looking closer at the description of the gas cap, it says "hinge pin with e-clip" is included, so you're probably good to go and don't need the Hondaman kit.
'71 CB500 K0
'81 Yamaha XS650
Honda3
« Reply #12 on: July 14, 2019, 06:13:51 AM »
Thanks!
Now onto the fuel tank emblems....
Im not sure if the Yamiya tank is an EXACT replica of the 1972 tank. Not sure if I need clips with the emblems? Also, whats a good place to get the left and right side emblems from? Anyone from the site sell them? Id rather throw them the business.
Offline Davez134
« Reply #13 on: July 14, 2019, 09:39:20 PM »
The Yamiya tanks are exact replicas. (I have one on my K2) You will need the clips to affix the Honda badges. As far as I remember there is no left vs right side emblem, same part number.
Honda3
« Reply #14 on: July 15, 2019, 05:33:04 AM »
Have you ordered a tank from them before? I ordered one on Saturday and am curious how soon they ship after you order. Time difference makes it hard to reach out to them.
Offline BenelliSEI
  • 1969 cb750
« Reply #15 on: July 15, 2019, 06:46:50 AM »
Tank storage: I mix some two stroke oil with gasoline about 50/50. Swill it around inside the tank (everywhere) and then dump it. If you ever want to use the tank again, repeat once with some clean gas......  Storage location is most important. Somewhere there are no temperature fluctuations (to avoid condensation in the tank).
Offline Clinto
« Reply #16 on: July 15, 2019, 11:39:30 AM »
any other pictures of your bike as is? especially interested in the exhaust
77 CB550F2
Offline Scott S
« Reply #17 on: July 15, 2019, 01:50:08 PM »
 Looks like 4 into 2's with Harley mufflers.
'71 CB500 K0
'81 Yamaha XS650
Honda3
« Reply #18 on: July 15, 2019, 02:16:25 PM »
This is a photo taken the day after I got it. took the rack off etc etc. but gives you a better idea of the exhaust. I was a total noob when I bought it and GAVE AWAY the original exhaust. lol. hated the way they look
Offline Scott S
« Reply #19 on: July 15, 2019, 04:24:20 PM »
 Now that you're going with the Yamiya tank set, it deserves original pipes.
 Or a MotoGP or Delkevic.
'71 CB500 K0
'81 Yamaha XS650
Honda3
« Reply #20 on: July 15, 2019, 04:37:38 PM »
Original pipes are a fortune and add to the weight. To be honest, with my current tailpipes I think it will look SLEEK.
« Last Edit: July 15, 2019, 05:02:07 PM by Honda3 »
Offline Davez134
« Reply #21 on: July 16, 2019, 06:32:23 AM »
Yes, I ordered a complete body set as well as an exhaust system from them. Shipping has been pretty quick in my experience. It's been a couple years, but I want to say it took around 1 week or so to get my stuff after placing the order.
Honda3
« Reply #22 on: July 16, 2019, 10:03:47 AM »
Thanks. They just emailed today to say they are shipping my order out tomorrow. Can barely wait!
« Reply #23 on: July 16, 2019, 11:33:11 AM »
I was worried that customs should scratch it when searching for illegal stuff.
No problem,. Japan post handled the very well packaged tank with side covers and so did the customs.
I'm sure you want to order another set in another colour to change with.
4-4 exhaust ordered too?
Inspect that all pipes are correct 1,2,3,4 and verify all diffusers.
I got mixed when ordered Lotus Root pipes.
I got one No numbers. Possible the other way too.
PITA with customs that had to see the original custom number to let the replacement part go to me without customs fee, vat etc.
They do not trust a long heavy package written gift on.
I have ordered parts from Yamiya at least 12-15 times, only one mistake they sorted quickly.
Honda3
« Reply #24 on: July 16, 2019, 12:14:07 PM »
Thanks.
I just ordered the tank and side covers, not the 4-4 pipes.
