« Reply #1 on: July 19, 2019, 05:58:48 AM »
depends on track surface and tire. You want your tire to step out in the corners and slide. Low pressure would make it handle and feel wonky. You really need to test during your warm up laps and see what works. I'd say start near 30 and go down from there. If you have good grip and the surface is good and sticky, you'd likely stay there. If there are a lot of marbles and the track never sets up, you may go down in pressure. I used to run a TT500 Yammie in short track years ago.
![](http://forums.sohc4.net/Themes/default/images/ip.gif)
Logged
