My X-Ray senses tell me that I have worn dogs on my 1st gear.
Taking off from idle (about 3/8th throttle, 2,500rpm) is egregious and stutters as though it’s slipping in/out of gear, almost sounding as though it’s trying to engage but cannot. I have to quickly engage clutch and shift into 2nd. I even have avoided 1st gear entirely and take off from 2nd gear, which I loathe.
I’m about to crack open my lower crankcase as I’ve done already now numerous times, yet the last time discovering and replacing my shift fork due to some noticeable wear:
I addressed the obvious issue by replacing the shift fork but didn’t think about nor look into why it occurred which brings me back to opening up the crankcase to examine the gears a little more carefully, zeroing in on 1st gear especially.
I know it’s probably been covered here before but I can find no definitive answer on what to look for when inspecting these potentially worn dogs. Rounded edges? Non-rounded corners? Undercuts?
I’m about to find out and I expect it to be obvious, but if any of y’all have some good references, I’d appreciate it.
