Dial gauge on the brake rotor shows 0.003 in. difference with one full rotation. Is that acceptable, or should it be 0.000?
Last night I disassembled, cleaned, and greased the caliper swing arm. After bleeding, I had a little progress where I could move the front wheel after applying the brake lever. It still took a lot of force to rotate, definitely isn't free spinning.
Knocked the back of the caliper to reset the pads and rode it down to the gas station, using only the rear brake. Checked the front rotor, it was still sizzling hot. But it did seem to roll better.
Master cylinder rebuild kit has arrived so that's next.
Is there a way to align the brake pad faces? I noticed the feeler gauge will be loose at the front but experience drag towards the back of the bad, closer to the engine.
