Author Topic: Should I have 2 Tees? 1977 CB550f  (Read 1649 times)
Offline 4ontheFloor
« on: July 20, 2019, 05:24:04 PM »
I bought the bike with two tees installed on my 77 CB550F.
I'm not getting fuel to at least one of the cylinders. Thanks
Re: Should I have 2 Tees? 1977 CB550f
« Reply #1 on: July 20, 2019, 05:54:53 PM »
 It looks like some big old 1/4" car fuel hose. I prefer the metric proper fuel line for bikes. Not sure why there are three fuel lines. Does the petcock have two outlets? If so one line should run to each pair of carbs. Someone may have been fixing a nonexistent problem.
Offline Thekramer666
« Reply #2 on: July 20, 2019, 06:37:23 PM »
Is the carb bowl filling up on that cylinder?
Please check your messages & follow up on your posts!!
76' CB550F SS
Offline Scott S
« Reply #3 on: July 20, 2019, 06:49:01 PM »
 Holy crap, none of that is stock.
 You should have two outlets on the petcock going to two inlets on the carbs. The fuel line enters on the front/engine side of the crossbar that holds all 4 carbs together.
 Get some 5.5mm fuel line and get rid of all that crap.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Deltarider
« Reply #4 on: July 21, 2019, 04:34:59 AM »
Depends on your model: F and F1 or F2. Cf. CB550F Partlists: http://www.honda4fun.com/materiale-documentazione-tecnica/parts-list/parts-list-cb550 > CB550F 4-1 (Super Sport).
« Last Edit: July 21, 2019, 04:39:59 AM by Deltarider »
CB500K2-ED Excel black
Offline 4ontheFloor
« Reply #5 on: July 21, 2019, 05:23:57 AM »
The vin says it's a 550F SuperSport, and it has a single outlet on the fuelcock.
I'll call around and see if anyone has 5.5mm fuel line.
Offline 4ontheFloor
« Reply #6 on: July 21, 2019, 05:25:37 AM »
I'll check now.
Offline BRG-BIRD
« Reply #7 on: July 21, 2019, 05:44:57 AM »
I have a two outlet fuel valve made for your machine, you can have it if you pay the shipping.
“You are either on something or onto something.” The Comman Man
Offline 4ontheFloor
« Reply #8 on: July 21, 2019, 06:03:13 AM »
Only carb bowl 1 has fuel in it.
« Reply #9 on: July 21, 2019, 09:59:28 AM »
 You can use the vinyl clear or colored 3/16 fuel line but it's not as fire resistant as the rubber fuel line.
 One of us should find a source of the good stuff and buy a roll of it, then re-sell bike sized kits. Would probably be less expensive.
Offline 4ontheFloor
« Reply #10 on: July 21, 2019, 10:04:46 AM »
I'm gonna buy some Rubber from the Honda Cycle shop on Monday. I took my carburetor off so you could get a better look at it.
« Reply #11 on: July 21, 2019, 12:42:01 PM »
There should not be anything in the middle for hose to hook to
« Reply #12 on: July 21, 2019, 12:53:49 PM »
Shipping cost these days makes that idea unprofitable.
Offline Scott S
« Reply #13 on: July 21, 2019, 01:19:49 PM »
 If you flip the carbs around you can see two holes in the main stay or bracket for the hoses to route through.
 Ebay and 4into1.com both sell 5.5mm fuel line by the foot. I buy a few feet at a time.
'71 CB500 K0
'81 Yamaha XS650
Offline pjlogue
« Reply #14 on: July 21, 2019, 01:58:44 PM »
I would be amazed if that set up didn't leave a trail of gas where ever it went.  I tried the 1/4" automotive fuel lines once in a pinch.  Pissed like a race horse all over the ground.  The 5.5mm Honda tubing is the best as it will not kink in a tight radius.
-P.
