I need some urgent advice, as I’m stuck about 350km from Addis Ababa with a flat battery and a charging system that has me stumped.
Changes to the stock electrics are: Hondaman ignition unit; electronic replacements for regulator and rectifier (from Horst on the German SOHC site); relays to save switches as per Hondaman; and an LED running light that is on all the time.
About 3 weeks ago bike wouldn’t start on electric starter; it worked OK on kick. I noticed that the headlight was switched on and had been all day while I tootled around in Kampala traffic at 0 kph which I reckoned could have run down the battery. I got the battery charged and all seemed well.
Until yesterday that is. It started Ok in the morning and ran well for about 60km. Then it started dying if the revs fell below 3000 rpm. Horn and flashers stopped working and then it died. Jump started it and it ran for about 1-2km and then died. Repeated this several times, trying to get to next town, before giving up. Battery removed and recharged.
It kept it’s charge till this morning and started fine on kick start. Ran fine for 40kms and then died. I put it on a truck and took it to the next town and set about checking the electrics thoroughly.
The battery voltage was 11.5 when I started. So why did the bike die? When I started teh bike with kick start, it ran well, but battery voltage dropped to +/- 7V and didn’t rise with revs; in fact it started to fall.
Checking components, these are the readings I got:
Alternator
Yellow to yellow - 0.6 Ohms - same for all 3 tests
Yellow to earth - no connection
Green to white - 7.2 Ohms
Green on the harness side is grounded.
Rectifier
All checked out with continuity in one direction and not in the other.
Regulator
Black wire shows battery voltage when ignition on and nil when off
Green to earth resistance 0.7 Ohms
White wire shows no voltage at all.
Voltage drop from battery +ve to black - 0
Voltage drop from battery -ve to green - 0
I connected white wire to regulator to battery +ve, leaving the green and black in place. Battery voltage didn’t change with rpm. Does this indicate alternator failure?
So it seems that each component is OK, but the battery is not charging! Why? Is the battery dead?
I know that I should be starting with a known good, fully charged battery, but getting a temporary replacement to test is difficult - they want you to buy one rather than lend one – and getting a new battery, with right spec even more so.
The battery is now being charged overnight, so any suggestions as to where I go form here will be a great help. Provided I can access them of course; govt keeps blocking the internet!
