Update:
Back in Ethiopia and have all the visas I need to get to Jordan. But the electrics continue to be a problem.
I left Addis with a fully charged battery and my new Dyna 5 Ohm coils fitted. About 100 miles out I noticed the voltage monitor was orange and then it started to flash. So I stopped short of my destination having covered about 150 miles and checked voltage - the bike died just as I got to a hotel. It was 6.5 volts!
Next morning with it recharged – happy I bought that charger – I set off again, but only made it 100 miles before same trouble.
Another recharge, this time with the aim of getting to next big town and trying to sort the problem once and for all. I was even considering getting a new battery, in spite of the previous bill of good health, even though this would require a trip to Johannesburg and back!
I almost made the 100 odd miles, but the bike died 12.5 miles out. This required a few hours in a roadside “garage coffee shop” to recharge the battery ..... again (see pic).
I made it to the hotel I was aiming for ... just.
Having put the battery on charge again, I set about going over the charging system again, from scratch. While checking the resistance between yellow alternator wires at the rectifier (hadn’t done this before), I discovered that the wiring from the rectifier (electronic replacement from Germany) plug did not match the wiring from the harness; only 2 of the yellow wires were connected!
So I guess this would mean I only had 2/3 of the charging current which would help explain why the battery was discharging. But, I have been running like this for some 12,000 km, although the problems only started about 4-5,000 km ago.
Is it possible that the battery was slowly discharging all along, but only recently was unable to keep up with the demands on it, given the weak charge it was getting?
The bigger question now though is, “Is the battery beyond it?” It will reach 13+ volts on the charger, but seems to drop quite quickly once removed. In a few hours it is down to 12.something. I have to decide whether to spend $600 or so to fly to Jo’Burg, plus cost of battery, plus cost of new visa ($100) or to risk going on with this one.
I plan to let it charge overnight; let it sit for a couple of hours; put it in the bike and test the charging current/voltage. If that is OK, then I’ll take it for a ride and see what happens. If green light stays on, then I’ll chance it ... maybe ...
Thoughts?
