Author Topic: 1979 CB750 Spoked Rims to Comstar Rims (please help)  (Read 1422 times)
Offline Connor1256
« on: July 26, 2019, 09:53:51 PM »
Hello everyone, in the process of buying new rims and tires for my build and am wondering if I can directly swap out the spoked rims I originally had on the bike for Comstar rims from the same year or an 80 or 81. Would any modifications need to be made to accommodate or would it be a direct bolt-on? Looking for a cheaper direct bolt-on option then brand new spoked rims. thanks.
Offline Bankerdanny
  • Endeavor to persevere
Re: 1979 CB750 Spoked Rims to Comstar Rims (please help)
« Reply #1 on: July 29, 2019, 02:51:59 PM »
The back wheel should be a direct swap, just make sure you get a drum brake rear. For the front so some research on the fork style. I think that the F models used a different fork lower style than the K/C models did. The wheels might be compatible anyway, but the probability is higher if you are swapping a single disk K/C wheel onto your single disk bike.
Offline tbpmusic
« Reply #2 on: August 11, 2019, 11:23:07 AM »
These swaps are easier to do if you swap the entire front end - then there are no wheel/brake/fender issues.
Bill Lane
Offline CB750Noobie
« Reply #3 on: April 02, 2020, 08:58:24 AM »
Connor, I'm in the same boat as you but with an 81 CB750K looking to go from Spoked to Comstars (for easier cleaning, tubeless tires, and I personally prefer the look of the comstars vs spoke). Did you ever get this to work? Your input would be of great value to me!
