Author Topic: 400F clutch basket removal help.  (Read 778 times)
Offline Kevin
« on: July 27, 2019, 06:22:06 PM »
Ack!!!
I need some advice on removing the clutch basket on my CB400F.
It’s been a few years since I have done this and can’t remember what the trick is.
I have the correct tool for the nut but can not keep the basket from turning.
I tried threading some bolts in and using a big screwdriver between them to keep everything from turning and ended up breaking the threaded stud on the clutch basket center (22120-377-000), ugh!!!
I also tried using an old school impact driver with little success. I do not have access to any air or electric impact drivers.
I looked in the Honda service manual to see if there was a special tool for holding the basket in place and it refers to a CB350F clutch basket, which uses a clip instead of the nut.
So if you have advice, and/or a replacement part for me I would love to hear from you.
Picture reference for how NOT to do it ;-)
Sent from my SM-N960F using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline Bodi
Re: 400F clutch basket removal help.
« Reply #1 on: July 27, 2019, 09:06:11 PM »
Put it in a a higher gear and jam the sprocket.
« Last Edit: July 27, 2019, 09:42:40 PM by Bodi »
Offline Kevin
« Reply #3 on: July 28, 2019, 02:17:35 AM »
Thanks Bodi!
I put some liquid wrench on the nut, went to lunch and read your suggestion. Went back and put it in gear and stuck a ¥10 (copper) between the gears and the clutch springs (3 out 4) installed with washers to keep the tension.
It busted loose - yeah!
Thanks again for the help!
Offline Kevin
« Reply #4 on: July 28, 2019, 02:21:18 AM »
https://www.ebay.com/sch/i.html?_nkw=clutch+basket+removal+tool+cb400f+&isNewKw=1&mfs=GOCLK&acimp=0&_trksid=p2053742.m2428.l1313.TR0.TRC0.Xclutch+basket+removal+tool+cb400f&sqp=clutch+basket+removal+tool+cb400f
And Bob's your uncle.
Thanks!
Have you used these before?
Even though I am done now I might just buy one so it will be easier next time.
Offline awrawr
« Reply #5 on: July 28, 2019, 05:54:16 AM »
Yes, works perfect every time.
