Author Topic: Quick carb question.  (Read 586 times)
Offline Spanner 1
« on: August 01, 2019, 10:26:05 PM »
On the early ( screw top ) 750 carbs which jet  do the air bleed passages in the carb throat supply . I.e., does the left one go to the main jet and the right one go to the slow jet ? Had a diagram, can't find it .
Offline disco
Re: Quick carb question.
« Reply #1 on: August 02, 2019, 01:22:46 AM »
The one with the brass insert goes to the main jet. The air passage with no brass insert is for the idle/low speed ie pilot jet circuit.
Note that the brass insert is always “towards the centre”. I hope that comes out clearly in the pics.
« Last Edit: August 02, 2019, 01:41:41 AM by disco »
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline Spanner 1
« Reply #2 on: August 06, 2019, 04:17:09 PM »
Thanks Disco !
