Author Topic: Apropos of nothing, earthquake info.....  (Read 950 times)
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« on: February 04, 2007, 08:42:28 PM »
Nothing like preparing for the inevitable, I suppose. And if you do not live in an earthquake zone it makes an interesting read.
EXTRACT FROM DOUG COPP'S ARTICLE ON THE "TRIANGLE OF LIFE", Edited by Larry Linn for MAA Safety Committee brief on 4/13/04.
My name is Doug Copp. I am the Rescue Chief and Disaster Manager of the American Rescue Team International (ARTI), the world's most experienced rescue team. The information in this article will save lives in an earthquake.
I have crawled inside 875 collapsed buildings, worked with rescue teams from 60 countries, founded rescue teams in several countries, and I am a member of many rescue teams from many countries. I was the United Nations expert in Disaster Mitigation for two years. I have worked at every major disaster in the world since 1985, except for simultaneous disasters.
In 1996 we made a film which proved my survival methodology to be correct. The Turkish Federal Government, City of Istanbul, University of Istanbul Case Productions and ARTI cooperated to film this practical, scientific test. We collapsed a school and a home with 20 mannequins inside. Ten mannequins did "duck and cover," and ten mannequins I used in my "triangle of life" survival method. After the simulated earthquake collapse we crawled through the rubble and entered the building to film and document the results. The film, in which I practiced my survival techniques under directly observable, scientific conditions, relevant to building collapse, showed there would have been zero percent survival for those doing duck and cover. There would likely have been 100 percent survivability for people using my method of the "triangle of life." This film has been seen by millions of viewers on television in Turkey and the rest of Europe, and it was seen in the USA, Canada and Latin America on the TV program Real TV.
The first building I ever crawled inside of was a school in Mexico City during the 1985 earthquake. Every child was under their desk. Every child was crushed to the thickness of their bones. They could have survived by lying down next to their desks in the aisles. It was obscene, unnecessary and I wondered why the children were not in the aisles. I didn't at the time know that the children were told to hide under something.
Simply stated, when buildings collapse, the weight of the ceilings falling upon the objects or furniture inside crushes these objects, leaving a space or void next to them. This space is what I call the "triangle of life". The larger the object, the stronger, the less it will compact. The less the
object compacts, the larger the void, the greater the probability that the person who is using this void for safety will not be injured. The next time you watch collapsed buildings, on television, count the "triangles" you see formed. They are everywhere. It is the most common shape, you will see, in a collapsed building. They are everywhere.
TEN TIPS FOR EARTHQUAKE SAFETY
1) Most everyone who simply "ducks and covers" WHEN BUILDINGS COLLAPSE are crushed to death. People who get under objects, like desks or cars, are crushed.
2) Cats, dogs and babies often naturally curl up in the fetal position. You should too in an earthquake. It is a natural safety/survival instinct. You can survive in a smaller void. Get next to an object, next to a sofa, next to a large bulky object that will compress slightly but leave a void next to it.
3) Wooden buildings are the safest type of construction to be in during an earthquake. Wood is flexible and moves with the force of the earthquake. If the wooden building does collapse, large survival voids are created. Also, the wooden building has less concentrated, crushing weight. Brick buildings will break into individual bricks. Bricks will cause many injuries but less squashed bodies than concrete slabs.
4) If you are in bed during the night and an earthquake occurs, simply roll off the bed. A safe void will exist around the bed. Hotels can achieve a much greater survival rate in earthquakes, simply by posting a sign on the back of the door of every room telling occupants to lie down on the floor, next to the bottom of the bed during an earthquake.
5) If an earthquake happens and you cannot easily escape by getting out the door or window, then lie down and curl up in the fetal position next to a sofa, or large chair.
6) Most everyone who gets under a doorway when buildings collapse is killed. How? If you stand under a doorway and the doorjamb falls forward or backward you will be crushed by the ceiling above. If the door jam falls sideways you will be cut in half by the doorway. In either case, you will be killed!
7) Never go to the stairs. The stairs have a different "moment of frequency" (they swing separately from the main part of the building). The stairs and remainder of the building continuously bump into each other until structural failure of the stairs takes place. The people who get on stairs before they fail are chopped up by the stair treads - horribly mutilated. Even if the building doesn't collapse, stay away from the stairs. The stairs are a likely part of the building to be damaged. Even if the stairs are not collapsed by the earthquake, they may collapse later when overloaded by fleeing people. They should always be checked for safety, even when the rest of the building is not damaged.
8) Get near the outer walls of buildings or outside of them if possible. It is much better to be near the outside of the building rather than the interior. The farther inside you are from the outside perimeter of the building the greater the probability that your escape route will be blocked.
9) People inside of their vehicles are crushed when the road above falls in an earthquake and crushes their vehicles, which is exactly what happened with the slabs between the decks of the Nimitz Freeway. The victims of the San Francisco earthquake all stayed inside of their vehicles. They were all killed. They could have easily survived by getting out and sitting or lying next to their vehicles. Everyone killed would have survived if they had been able to get out of their cars and sit or lie next to them. All the crushed cars had voids 3 feet high next to them, except for the cars that had columns fall directly across them.
10) I discovered, while crawling inside of collapsed newspaper offices and other offices with a lot of paper, that paper does not compact. Large voids are found surrounding stacks of paper.
Spread the word and save someone's life...
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline medic09
Re: Apropos of nothing, earthquake info.....
« Reply #1 on: February 04, 2007, 09:10:32 PM »
Well, my SAR experience pales compared to Mr. Copp's; but I flinch at the mention of his name.  See, for example, this link from Snopes:
http://www.snopes.com/inboxer/household/triangle.asp
http://www2.bpaonline.org/Emergencyprep/arc-on-doug-copp.html
http://www.cert-la.com/RejoinderToDougCopp.pdf
This one's been around for a few years.  I don't stay on top of all the material in my fields, but I do stay interested.
Mordechai
Combat Medic 09, IDF
Atalaya Search and Rescue, Santa Fe, NM
Mountain Canine Corps SAR, Los Alamos, NM
Med Flight Air Ambulance, ABQ
Pecos Valley Ambulance Service, San Miguel County, NM
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Uncle Ernie
« Reply #2 on: February 04, 2007, 09:32:32 PM »
I was in downtown San Francisco during the quake of '89.  The best way to survive is get as drunk as possible FAST.
Offline nickjtc
« Reply #3 on: February 04, 2007, 10:19:01 PM »
OK. So now I'm completely confused. What information is a person in an earthquake prone area supposed to use?
One side says the triangle zone is the best...the other side says that there is no evidence that this safe zone was actually there at the time of the earthquake and that the 'old fashioned' safety protocol is better. A person could be killed just trying to make up their mind where to seek  an appropriately safe area.
I like Ernie's idea, and better still, stay away from danger areas in the world.
1977 Suzuki GS750
Offline medic09
« Reply #4 on: February 05, 2007, 04:28:25 AM »
I'm not advocating a position; just pointing out that we don't know that Doug Copp is a good source of info.
Mordechai
'78 CB750K
Santa Fe, NM
Offline Uncle Ernie
« Reply #5 on: February 05, 2007, 06:51:44 AM »
The places that always survive are built on rock.  Downtown SF is all landfill from Battery St to the Embarcadero.  Loose land shakes more.  The Berkely Hills, for instance, do just fine- all one big rock.
If you're not on rock, there's one position to assume; sit on the floor next to a wall, hold your knees up, put your head between your knees, and kiss your ass good-bye.
Serioously- I blieve he's right aboout getting out of the car on the Bay Bridge.  I can't imagine just sitting there and watching that top deck rolling down on you.
Offline Rushoid
  • Shameless
« Reply #6 on: February 05, 2007, 12:52:25 PM »
I was across the bay in Alameda. We had a big party outside the barracks, looking at the collapsed section of the Bay Bridge, when the brass told us we couldn't occupy the buildings until they were "inspected" (they didn't notice the gaping crack in our wall).
We all thought it was pretty cool until the news reports started coming in. We spent the next few days supporting rescue workers who were pulling bodies out of the Cyprus Structure. I don't think most of those people would've had time to lay down next to their cars even if they had acted instantly.
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
