Author Topic: Another CB550 Not Charging Thread  (Read 7018 times)
0 Members and 17 Guests are viewing this topic.
Re: Another CB550 Not Charging Thread
« Reply #25 on: August 09, 2019, 08:37:07 pm »
Ground both the field green and regulator green wires and test.
Offline TowelThief
« Reply #26 on: August 11, 2019, 03:54:47 pm »
OK.
I disconnected the R/R green wire from the block connector and grounded it to the frame.  I then jumped a spare wire from the block connector (green) to the bracket on the right where main ground connects.
My measurements from White (connected from R/R to block connector) to ground.
Flip the Key on......11.8vdc  (lights on)  Running @ idle it was at 12vdc...@3K rpm it only went up to 12.05vdc.
Battery doesnt show any 'charging'
While it was running I checked the VAC coming from the 3 yellow wires and im only getting a .5v @ idle and up to 1.6V @ 4k rpm....I havent done it yet but if I were to unplug the yellow wires at the block connector to the R/R and then measure VAC coming from the stator I would get 18v at idle (just like I explained in an earlier post)....would that mean a bad rectifier?
Now...I can also get 12VDC from White to Ground by disconnecting either (or both) of the field coil wires (white and green) from the connections between the field coil and the block connector.
« Last Edit: August 11, 2019, 07:09:52 pm by TowelThief »
« Reply #27 on: August 11, 2019, 11:26:22 pm »
You should be measuring the voltage at the battery terminals, not at the output of the regulator on the white wire, which needs to be connected to the white field coil wire for the system to work. Since the voltage did increase with rpm, it would appear that your system may be charging, but since the battery is run down, it will take time to recharge and the voltage to come up.
Offline TowelThief
« Reply #28 on: August 12, 2019, 05:50:43 pm »
New measurements with the green wires now grounded are as follows.
Bike on and running with lights
Volts of Battery = 12.85V when @ idle (1200-1300)
R/R Black to Ground = 12.05V
R/R White to Ground = 12.05V
BATT POS to R/R Black .785v idle
BATT NEG to R/R Green 12.05V idle
I ran it for about 5 minutes....when I would get up to 3k-4k I would get about a .01-.02V change upward but the battery slowly went down to 12.77V before I ended the testing....am I not suppose to see 13.5V on the battery @4k??
Turning the lights off gives me another .10V but still doesnt show a jump when giving it gas at 3-4k rpm
« Last Edit: August 12, 2019, 07:27:13 pm by TowelThief »
« Reply #29 on: August 12, 2019, 10:58:44 pm »
Battery neg to either of the R/R greens should be near zero volts in any case, at any RPM. If you are reading 12v, the green wire is NOT grounded.
Offline TowelThief
« Reply #30 on: August 13, 2019, 04:29:08 pm »
I apologize.  I was measuring the green field coil wire at the block connector...these wires are all starting to blend together  :o
BATT NEG TO R/R Green is .5mV while at idle.
Still no charge on the battery....AC voltage from the stator wires reads .3-.4 VAC across the three at idle. Goes to about 1.5V at 5k.  Same readings if I disconnect the three stator wires from the R/R.
« Last Edit: August 13, 2019, 04:36:00 pm by TowelThief »
« Reply #31 on: August 14, 2019, 12:19:00 am »
I am now confused, you said if you put battery power to the green and the white field coil wires you got 60vac at the yellow leads, and later you said you were getting 13 ish vdc at the battery,  if those numbers are correct no matter what type or how old the battery is IT IS JUNK
« Reply #32 on: August 14, 2019, 12:37:23 am »
You do understand that the bike is not capable of recharging a discharged battery and that it can only maintain and charge a good battery.???  If your battery is good then the bike with a healthy charging system can maintain the bike's power needs and replace what is taken out of the battery if it is ran often /long enough at RPMs that are providing a charge surplus. Operating for short trips at lower rpms  you would see in short city trips won't keep the battery charged and it will need to be charged by a battery charger to keep the battery healthy.
Are you recharging the battery between these tests you are performing?
The numbers you are quoting for your battery voltage readings are not that of a healthy lead acid battery or a healthy Lithium battery either.
« Reply #33 on: August 14, 2019, 08:38:57 am »
What was the charge state of the Battery?  The battery charge status dominates the system voltage.  Not the charging system.
A flat battery can take 10 hours on bike @ 4-5K RPM to reach a full charge status and full voltage.
All charging voltage test must be done with a known good fully charged battery, in order to evaluate the charging system, rather than the battery condition or quality.
A low or dead battery is a huge sink, that will tax a charging system that normally only provides 1-2 amps for battery recharge.   Conversely, a good battery easily can supply 100-120 amps for starting purposes, and far more under direct short of it's output terminals.  You can weld metal with the battery in good condition.  The charging system can't do that!
If the alternator field is being provided full battery voltage or there abouts, the alternator is doing the best it can, in proportion to the rpm it is spinning.  150 watts minimum at 5000 RPM, and about 1/3 of that during idle. The bike total electrical load includes battery demands.  The battery charge state dominates the system voltage, not the charging system.  The Vreg only protects the battery from too high a voltage when it is at full charge, reducing the green/white voltage.  At all other times it should be drive the alternator with full voltage so it is able to produce all it can, which supplies both bike loads and battery needs.
Offline Bodi
« Reply #34 on: August 14, 2019, 08:45:54 am »
If you have ground on one field coil wire and battery voltage on the other, that's 100% alternator output at whatever RPM it's doing.
You can do a hillbilly field coil check by holding a steel tool on the alternator cover: with field coil energized you should feel a definite magnetic attraction toward the cover, nothing with field coil off. Thise coils are pretty much bulletproof but could fail. You could also measure field coil current with an ammeter, it should be around 4 amps I think.
« Reply #35 on: August 14, 2019, 08:53:04 am »
Bodi helped me think about asking if you have measured the resistance of the field coil?
Best be about 4.8-ish ohms, excluding measurement error.  Measure this from the White green connections at the vreg, with vreg disconnected.
Offline TowelThief
« Reply #36 on: August 15, 2019, 01:14:43 pm »
Sorry I have been busy these past few days and can’t run tests until the weekend. I plan on providing you guys with some more information to better clarify what I’m looking at.
Ohms of the Field Coil are 4.0. That’s with resistance of the leads on my meter factored in.
« Reply #37 on: August 15, 2019, 02:31:31 pm »
That's a bit low.  If accurate, it will reduce the efficiency of the alternator, lessen it's output peak.  Indicates shorted windings.
« Reply #38 on: August 15, 2019, 11:42:04 pm »
The green field coil wire should also be zero volts from the battery negative terminal. ALL solid green wires are connected to ground.
« Last Edit: August 15, 2019, 11:47:02 pm by scottly »
Offline TowelThief
« Reply #39 on: August 17, 2019, 12:05:07 pm »
My battery numbers are consistent....It is a lithium ion battery...sits on a 750mA charger when im not testing it.  Off the charger its 13.56V....after an hour there is no change....Turn Key (running brake lights and a speedo light) 13.2 (with Headlight 12.9)....After running tests for an hour with lights and stopping and starting the bike, the voltage obviously goes down.  I have done tests with a brand new lead acid battery with no change in results (I believe I reported that in an earlier post)
I hotwired it today.  When I just hotwire the POS Batt to white and NEG Batt to green in the block connector I get 18VAC between the yellow wires and idle about 20 @ 2k and up to 60 at 5k....obviously no charge to battery.
When I add the 3 yellow R/R wires to the block connector with the above hot wire I get 10 VAC between the yellows at idle and only up to 12VAC at 5k..the battery charges from 12.9 at idle to 13.3 at 5k.
I was working with a bad test wire that I was connecting to the Field coil green and ground....I replaced it and these numbers followed.
Right, so the Ricks R/R has 3 Yellow/ 1 White / 1 thinner Green / 1 Black / 1 Thick Red / 1 thick Green.
They were connected as shown in the Diagram on an early post....yellows, white and thin green to the block connector...black to AUX Fuse block....thick red to POS.....thick green to NEG.
I was getting 14.1mV on white when on and 1.2mV on block connector green
If I disconnect the thin green from the block connector I get 12V on the white wire....I also get 12V on the green connector tab....
If I GROUND the thin green R/R wire and use a test wire to ground the field coil green (from block connector to ground).....white read 12.9mV at the block connector and green at the block connector reads .3mV
The White wire gets 12V when the bike is on and its not connected to anything....just dangling from the R/R.
« Last Edit: August 17, 2019, 12:09:02 pm by TowelThief »
« Reply #40 on: August 17, 2019, 12:25:10 pm »
One last time YOUR BATTERY IS CRAP
Offline TowelThief
« Reply #41 on: August 17, 2019, 01:28:35 pm »
I hope so that would be the cheap option.
Offline calj737
  • I refuse...
« Reply #42 on: August 17, 2019, 04:04:26 pm »
Except you seem to be measuring the same results with a different battery. Kind of dispels that theory...
« Reply #43 on: August 17, 2019, 04:59:05 pm »
This is still the Rick's unit which is NOT designed for Lithium batteries, right?  Wouldn't that be one of the things you should be changing so the Lithium battery has a prayer of being treated better?
Offline TowelThief
« Reply #44 on: August 18, 2019, 08:37:24 am »
I believe the only difference is the voltage set point. 14 +/- .2 for the 14-100 (lithium) and 14.8 for the 10-100.
At this point I am going to start replacing items.
Sending the Field Coil for a refab.
Getting a new R/R.
Trying yet another AGM battery or a new Shorai.
Thanks guys. Will check in later.
Offline TowelThief
« Reply #45 on: August 21, 2019, 07:46:52 pm »
I'll preface this post by saying this bike was given to a "bike builder" to finish when I joined the military....I picked it up a year after dropping it off...it ran, until it died on me and I tested the battery and found out it wasn't charging.
I vaguely remember him saying he "upgraded" the coils...after reading a bit tonight and seeing that the coils effect the charging system I went out to check them.
They are TEK MP-08 coils...they seem to be off of more modern bikes and measure 3.4ohms across the pins...could this be sucking all the charge?
« Reply #46 on: August 21, 2019, 10:25:14 pm »
No, the coils are not the problem.
What is this "block connector" you keep referring to? Please post a pic.
This isn't a stock wiring system, so we have no idea how it's wired. Your stator tests good, and hot-wiring the field coil proves it's good as well.
« Reply #47 on: August 22, 2019, 12:39:34 am »
The battery is not accepting charge pleas fit a lead acid one instead of all this lithium crap
Offline calj737
  • I refuse...
« Reply #48 on: August 22, 2019, 03:24:53 am »
You haven't paid attention at all.
His battery and stator are fine. The problem lies in the wiring or the R/R itself.
Offline titochachang
« Reply #49 on: August 23, 2019, 12:03:25 pm »
I have been told the closer to 5.0 the better...
