Author Topic: 1977 750F Clutch Lever Bolt  (Read 447 times)
Offline reliv77
« on: August 08, 2019, 02:28:26 PM »
Is the Clutch Lever Bolt supposed to be a smaller size in diameter than the Front Brake Lever Bolt on my 77 750F?
Re: 1977 750F Clutch Lever Bolt
« Reply #1 on: August 08, 2019, 05:39:32 PM »
No, same special bolt, #90114-300-000. If someone slipped one in from an era Suzuki, it might be a simple 6mm bolt with a collar around it to rotate on. :)
Offline reliv77
« Reply #2 on: August 09, 2019, 10:37:17 AM »
So I am guessing that I do not have the correct Front Brake Lever or correct Clutch Lever because the bolts are not interchangeable.
