SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Where do these wires go? Cb750
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Where do these wires go? Cb750 (Read 2399 times)
Prospect
Expert
on:
August 13, 2019, 01:44:33 PM »
It's been a very long while since I did this but where do these two wires go. Probably the one from the engine goes to the starter solenoid but the one from the negative terminal goes to a ground point. Can't remember where it goes (probably somewhere on the frame).
Sent from my Pixel 3 using Tapatalk
Logged
Current Bikes
1969 CB750 Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Bankerdanny
Eventually I will be old enough in reality to be
Really Old Timer ...
Endeavor to persevere
Re: Where do these wires go? Cb750
Reply #1 on:
August 13, 2019, 02:40:33 PM »
The one in your hand should be the starter power cable and it goes to the starter solenoid on the left hand terminal (the one with the loose nut in your photo).
The one sticking out of the frame looks like the ground connection to the battery, it usually bolts on at an engine mount.
Logged
Current: '76 CB750F. Previous: '75 CB550F, 2007 Yamaha Vino 125 Scooter, '75 Harley FXE Superglide, '77 GL1000, '77 CB550k, '68 Suzuki K10 80, '68 Yamaha YR2, '69 BMW R69S, '71 Honda SL175, '02 Royal Enfield Bullet 500, '89 Yamaha FJ1200
robvangulik
Honda Fourever
Expert
Reply #2 on:
August 13, 2019, 02:44:43 PM »
Danny is right, and the ground cable mounts at the right rear engine mounting point, the top of the detachable plate.
Logged
Prospect
Expert
Reply #3 on:
August 13, 2019, 03:33:52 PM »
Thank's so much. Couldn't remember
Logged
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Kevin D
Old Timer
SE Michigan
Reply #4 on:
August 13, 2019, 04:29:55 PM »
Clean the connection points, no paint, no rust, no corrosion, add a little grease, for a happy electrical system.
Logged
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
rotortiller
Expert
Reply #5 on:
August 13, 2019, 09:15:09 PM »
I being a deviant, installed mine (750K7) under the aft top right engine mount bracket. That way it is firmly bonded to the engine, sandwiched and hidden between the two. That way frame bracket paint does not have to be removed thus offering the best high current (-) electrical path for the starter and alternator to the battery. The negative path for the frame to the battery to run accessories has enough roads through the numerous motor mounts which is easily verified with an Ohm or Volt meter. With fresh power coating you really should check electrical bonding.
Logged
Don R
My Sandcast is a
Saver of unloved motorcycles.
Reply #6 on:
August 14, 2019, 06:52:51 PM »
What he said ^.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
