Author Topic: Best black touchup paint for 77 CB400 frame and components?  (Read 785 times)
Offline mattsz
« on: August 13, 2019, 04:21:04 PM »
There's so much info here, I couldn't sort through my search results!
Can anyone recommend a particular brand, color and shine of rattle can paint - preferably readily available throughout the US - that would be a decent match for the frame and side stand of my '77 CB400F?  I assume the frame was painted originally, but not sure about the side stand (did Honda powder coat anything in the 70's?).
I've used some heat to straighten some bent bits and ruined the coatings in the process - I'd like to repaint them before I reinstall them.  It's not a concours restoration, close is good enough - it's the protection I'm after...
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Best black touchup paint for 77 CB400 frame and components?
« Reply #1 on: August 13, 2019, 04:38:08 PM »
I think I remember someone mentioning harbor freight appliance black.
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
Offline tlbranth
« Reply #2 on: August 13, 2019, 05:59:11 PM »
I use Hammerite smooth gloss black for touchup
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #3 on: August 13, 2019, 07:16:51 PM »
Rustoleum gloss black is a perfect match.  Appliance epoxy is a little too shiny until it gets dirty and cleaned a few times but more durable than any other spray can I have used.
Offline mattsz
« Reply #4 on: August 14, 2019, 02:44:16 AM »
Thanks guys!  I should be able to find at least one of those locally...
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: August 14, 2019, 09:50:33 AM »
I have mentioned this product in several posts. It is easy to find and almost identical to stock.
Offline mattsz
« Reply #6 on: August 14, 2019, 02:15:33 PM »
Thanks!  They offer three different primers - Gray Self-Etching, Gray Sandable, and Gray Filler.  Which one, if any, do you suggest?
Offline Bankerdanny
« Reply #7 on: August 14, 2019, 02:18:36 PM »
I generally only use self-etching when painting 100% bare metal. If you have just a few bare metal spots either of the other two options should work fine and I have also sprayed the frame paint without primering.
Offline mattsz
« Reply #8 on: August 14, 2019, 02:29:27 PM »
Well, at this point it's just spot touch-ups as part of a "see if it runs" job on what will be a fair-weather ride... nothing like a restoration. I've got a can of Rustoleum self-etching primer on hand, so maybe I'll test their compatibility and just use that if they play nice together...
Online Tim2005
« Reply #9 on: August 14, 2019, 02:44:37 PM »
Same here, it's great paint. you can even use it on exhausts with just a little care, and silver version is great for crankcases (when used with their "special metals" primer)
