Author Topic: PD42s  (Read 487 times)
PD42s
« on: August 17, 2019, 05:14:28 AM »
Please, educate me on PD42s.
What's the difference between  A and B?  Are they interchangeable?  Different jets only?  Bit lost here.
Re: PD42s
« Reply #1 on: August 17, 2019, 06:02:36 AM »
PD's are a nightmare, thats all i know
Offline Erny
Re: PD42s
« Reply #2 on: August 17, 2019, 11:25:01 AM »
A has adjustable needles (still has grooves) while B not (shimming seems to be the only option). Shop manual shall show jet differences if any
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Re: PD42s
« Reply #3 on: August 18, 2019, 02:46:21 AM »
Thank you.   This table:
http://www.hondachopper.com/garage/carb_specs/carb_specs.html
shows the difference in jetting.
From what I could find, there is also difference in venting.
Online HondaMan
Re: PD42s
« Reply #4 on: August 18, 2019, 11:16:17 AM »
The "B" is the emission-controlled version of the "A", which was the emission-controlled version of the earlier carbs.
You can use "A" parts in the "B" version: in fact, if you jet the "B" the same as the "A", and give the "B" a little longer vent-bowl hose to a quieter area (like under the seat), it will work the same as the "A". If you have "B" carbs and suffer from chronic cold-bloodedness, increasing the [press-in] pilot jet from the normal #35 size to the #37.5/#38 /#40 of the "A" will solve it. The air screw setting on the "B" carb is miserly, between 1.5 and 1.75 turns: past 2.0 turns it makes no further difference (richer) because the air port is very small. At 1.75 turns the A/F mixture is about the same as the "A" carb with #38 pilot jet and 1.5 turns, a bit lean.
In both versions: the #1 trouble I find is with the tiny O-rings in the pilot port (air screw seat) having been installed backward by someone (after Keihin). The O-ring goes in first, then the washer. If backward, it will struggle to idle at all.
Re: PD42s
« Reply #5 on: August 18, 2019, 11:38:48 AM »
Thank you, Mark.
