Mr. Breeze,
Do choose a kit made for full replacement. It's more than just the special tapered bearings - you'll need the special needle bearing races and there are "stack" washers you'll use to obtain the exact same "stack height". You have to remove your triple tree and the bottom race from the frame neck. Then you assemble the 1/4" original balls and race from the frame to get a stack height measurement. Then, using the new kit's included spacers and thickness washers, you have to assemble the new races and bearings to achieve the same, exact height. Only a kit is going to have the special instructions on how/what has to be done. It's an easy install, but it is NOT a straight drop-in upgrade, measuremens and assembly is required.
Remember - if you'll stick that triple tree into the freezer the night before and set the bearing under a hair dryer or heat gun - those slide on super easy. Make sure your powdercoater mask the machined shaft completely and does the inside radious of the fork clamps. You cannot install if the powder is on any part of the shaft.
I have used the All-Balls sets on several bikes, including my K4 CB750. I really like their kits and they are well priced.
Regards,
Gordon
