Hello All...installing RS34's. Have float heights traditionally adjusted to 18mm...was looking for the correct clear tube spec from bowl mating surface and can't find a clear answer. KZRider site bounces back and forth on the actual proper mm distance.
Anybody have this info handy with experience. I've seen 2.5 - 3.5mm below mating surface but then that appears to need adjusting to upwards of 21mm on the mechanical check.
I know these are a pain to put on and take off...so trying to bench set everything I can
joe
