Author Topic: Cb550 can chain adjuster oil leak  (Read 566 times)
Offline Can550
« on: August 30, 2019, 09:41:34 AM »
Oil is seeping out of cam chain tensioner adjuster. I see on parts catalog that there’s an O ring there. Anyone replaced, would like to know size. (Does it have to an OEM or any correct size will do)
Thanks
Offline Scott S
Re: Cb550 can chain adjuster oil leak
« Reply #1 on: August 30, 2019, 10:57:27 AM »
 I just replaced one with a Viton o-ring from the multi pack set that Harbor Freight sells. Sorry, I don't remember the size. I just use the old O ring and found the closest match. Gently pushed it in snug, reinstalled the nut and washer and adjusted the cam chain. No more leaks.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Can550
« Reply #2 on: August 30, 2019, 11:27:31 AM »
I was thinking of replacing O ring while it is there. It seems you replaced when engine was apart or cam chain was out ?
  • I'm back
« Reply #3 on: August 30, 2019, 01:01:34 PM »
Why not just put any O-ring under the washer? I mean you always run the engine with the lock nut tightened, don't you?
Offline Scott S
« Reply #4 on: August 30, 2019, 04:05:44 PM »
I just removed the locknut and washer, fished out the damaged O-ring with a pick tool and pushed in a new one. Reinstall washer and locknut, adjust cam chain. Engine was fully assembled.
'71 CB500 K0
'81 Yamaha XS650
Offline Can550
« Reply #5 on: August 30, 2019, 04:39:01 PM »
Great
Thanks
