And here are some wiring diagrams.
Bandit 400, with a close up of the dash wiring.
![](https://i.imgur.com/OJ509ea.jpg)
![](https://i.imgur.com/fX69gfJ.jpg)
And 750 wiring.
![](https://i.imgur.com/ibah1wO.jpg)
There are a couple of wires I won't be using....fuel gauge, water temp, etc., but the colors are consistent on both harnesses.
Ground - B/W black/white
Keyed power - GR gray
Tach - B/Y black/yellow
Turns - Black for LH and Light Green for RH
Neutral - LB blue/black
Hi-beam - Y yellow
Oil Pressure - G/Y green/yellow
Fused Power - OG orange/green
I won't be using the side stand switch or clutch switch (this is all going in a GS550 frame). If I just use a jumper for those two switches, will the turn signal/side stand relay in the 750 harness still supply the correct power and ground to make the neutral light work?
I studied the 750 diagram yesterday and all of the colors I need match up. I ordered a Bandit 400 harness to rob the plug from.
On the Bandit 400 diagram, OG is switched power from 10A fuse (4 Signal) for turn signal flasher, back brake switch, horn, front brake switch, side light switch and pilot lights. Neutral light is supplied via switched live from OG, LB is earth via the side stand diode to the neutral switch.
The 750 doesn't use a diode (or, if it does it's inside the turn signal/side stand relay....lower right in the 750 diagram). Sooo....if I just use a jumper to bypass the side stand switch and the clutch switch, will that relay still supply power to make the neutral light work?
