Author Topic: Need new Shocks-Help  (Read 1988 times)
Offline frenchy51
« on: September 05, 2019, 02:04:28 PM »
I'm needing new shocks for the rear on my '76 CB750F. I was going to use Hagons but I think they're no longer in business. I see "Vintage CB750" offers reasonably priced ($109) Stock Length replacement shocks. Has anyone used them? (ie-part #'s 06-3623 or 06-3603) I'm no racer. Just a short trip old guy. I'm 6' 190 lbs. Looking mostly for a good ride-Thanks for any and all advice.
1976 CB750F SURVIVOR
Offline robvangulik
  • Honda Fourever
Re: Need new Shocks-Help
« Reply #1 on: September 05, 2019, 02:34:06 PM »
The USA website says:
All Items Can Be Purchased Direct From Hagon Products Ltd UK
So why don't you try that?
Offline frenchy51
« Reply #2 on: September 05, 2019, 02:41:20 PM »
Found their site but no listing for a CB750F....rather deal with a US based company anyway. Thanks for the reply
Offline jakec
« Reply #3 on: September 05, 2019, 03:32:43 PM »
IKON shocks
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline Scott S
« Reply #4 on: September 05, 2019, 04:06:12 PM »
 I'm happy with my ikon shocks, but you won't get a set for $109.
 I had some very limited time on a bike with YSS shocks and was very impressed.  Still not $109, but more affordable than the ikon's.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: September 05, 2019, 04:39:33 PM »
You don't need to buy F specific shocks.
« Reply #6 on: September 05, 2019, 05:11:54 PM »
You need shocks that have a long lower straight section to fit around the chain guard, and 110-lb straight-wound springs for your weight. Avoid the 'progressive' spring rates, as you will find them to be very squishy and will make you wobble in turns. Most progressive springs are about 90 pound start, ending in 120 to 130 lbs. The length you want is 12.9" ideally, but will find mostly 13" long ones.
Offline frenchy51
« Reply #7 on: September 06, 2019, 04:55:53 AM »
Thanks everyone for the replies. Also-thanks to this forum I found a set of lightly used Ikons and they are on the way.
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #8 on: September 06, 2019, 05:33:04 AM »
I went with 1in shorter hagons , to lower bike a tad, they are Way better than OEM.
Offline dtkay428
« Reply #9 on: September 12, 2019, 06:16:26 AM »
I'm also in need of new shocks. I will be riding two up 90% of the time. Any thoughts on spring rate for 190 lb rider and 140 lb passenger?
Offline Plzhalpimlost
« Reply #10 on: September 20, 2019, 02:18:09 PM »
Bump. I’m also interested in the best 2-up springs.
Offline Doobie
« Reply #11 on: September 20, 2019, 03:01:21 PM »
Check out the Ikons. Believe there is a member's discount for them. Has both rebound and preload unlike some others.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #12 on: September 20, 2019, 03:22:36 PM »
+1.  I bought mine from Nils at RestoCycle, contact him for specific info...
https://www.restocycle.com/ikon-suspension-products
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #13 on: September 21, 2019, 07:07:02 AM »
YSS makes a $119 pair.  not sure if they offer it with a clevis bottom.
cb750 k6 - ugly
