Author Topic: 1 rich cylinder - is it the carbs? PD46C  (Read 2407 times)
Offline cwchan
« on: September 16, 2019, 09:43:09 AM »
Hi All,
Everytime i tune up the bike i learn more about it and slowly get it running better and better.
I feel like i'm close to a bike that runs perfectly.... when pulling the plugs, cylinder #2 is rich and the other cylinders look slightly rich but good.
I have a uni foam air filter on the stock airbox, stock exhaust.  The cylinders were honed last winter (stock bore).  A number of years ago i got the valves re-seated and the valve guides done (drilled out and bronze lined?? - the mechanic said it would be easier, cheaper and better than replacing the valve guides).  Valve spacing is set.  Rechecked (the next day to let it cool) after running it as i found that sometimes the nut would loosen a little.  I got dyna coils and dyna s ignition.  One thing that made a big difference in ignition timing is making sure that the 23mm nut is centered on the 10mm bolt that goes into the crankshaft.  There was a wobble when un-centered that was throwing off the dyna s magnet.
That leaves me with the carbs.  Cylinder #2 has been rich (carbon fouled) as far as i can remember and i've never personally dived deep into the carbs until recently.  I dropped it off at Sirius Consolidated years ago for their carb service and it was crap.  They put 88 main jets in there, the floats were set all over the place, and the pilot screw spring in carb #4 was too short.  Fixing the floats and screw spring gave me a huge improvement in how the bike idles.
My current carb settings are:
Main jet: 95 (the 88s i had were too lean and the only other ones i have are 110s at the moment). 2,110 ft elevation
Slow jet: unknown.  i don't recall ever seeing an etching indicating the size on these.  It doesn't look like they've ever been removed
Needle position: unknown.  This is my main suspect.  i'm wondering if they are set differently
Air screw: 2 turns out
Carbs are synced.  The no-name sync tool has 4 gauges and i found they all read slightly differently.  I made sure to check the vacuum reading on the same gauge for all cylinders by constantly switching out the tubes.  This was essentially like syncing with one gauge.
I have the bike at a stage where i can live with it but i'd really like to get it dialed in.  Driving around in stop and go traffic it idles between 1000-1300 (digital tach wired into harness).  It doesn't surge wildly like it used to.  If i rev it, it jumps up and falls back down to idle quickly.
So i plan to dive into the carbs this winter but i'm wondering if there is a key spot i should look at and focus my efforts.
I've had this bike for almost 10 years now.  I've gone through my old posts and i really feel good about the how much i've learned.  Sometimes i thought i solved a problem only to find out later that the true problem was elsewhere.  I really inherited a basket case.  Its in a really good state now, comparatively.  I want to get it just that much better
Thanks in advance
« Last Edit: September 16, 2019, 12:20:23 PM by cwchan »
Offline pjlogue
Re: 1 rich cylinder - is it the carbs? PD46C
« Reply #1 on: September 16, 2019, 11:00:49 AM »
Easiest thing to do is check for an air leak at the carb-cylinder intake boot.  Use a can of carb cleaner and spray each boot to carb seal and head to boot seal with the bike idling and warmed up.  If the RPM changes you know you have a leak.  An air leak will cause a rich condition on these pulse induction carbs.
-P.
Offline Deltarider
« Reply #2 on: September 17, 2019, 03:36:00 AM »
... An air leak will cause a rich condition on these pulse induction carbs.
-P.
Forgive me my ignorance, but can you enlighten me on this?
CB500K2-ED Excel black
Offline maxheadflow
« Reply #3 on: September 17, 2019, 07:21:01 AM »
I don't see when the carbs were last synchronized.
I'll agree on the manifold leak.  Seems to me that it would make the cylinder run lean.
Offline pjlogue
« Reply #4 on: September 17, 2019, 12:29:27 PM »
I read this in Mark's book under the carb section and I have also experienced this on my K6.  I can't remember the specifics as to why this happens but I'll review it tonight and see if I can find it.
My outboard cylinders were running rich and I could not figure out why.  I read Mark's book and then checked for air leaks at the boots and sure enough both had an air leak.  Fixing the air leak (clamps were stretched so I fit a band of gasket material under each band) solved the air leaks on #'s 1 and 4 and with no other adjustments my plugs were no longer black all the time.
-P.
Offline cwchan
« Reply #5 on: September 17, 2019, 06:12:54 PM »
Ok. I check again... the issue I had with spraying the carb cleaner is that it evaporated quickly after spraying
I synced last week. Maybe I recheck it tomorrow
Offline Deltarider
« Reply #6 on: September 17, 2019, 10:36:50 PM »
I'm afraid I don't understand. Spraying is done whilst engine is idling. It should work.
Offline cwchan
« Reply #7 on: September 17, 2019, 10:56:40 PM »
The engine was warm and the carb cleaner evaporates soon after it is sprayed on the warm engine
Offline Deltarider
« Reply #8 on: September 18, 2019, 12:22:35 AM »
Have a look at this picture if you like. Forget about the arrows. They are there to point out something else. You are supposed to spray to the front and rear of the rubber boot where it is fastened to the manifold (front) and the carb (rear) and also where the manifold meets the head. In that spot there's an O-ring that may have become old, hard and brittle. Spraying a mist of either brake cleaner or carb cleaner will immediately change the rpm indicating a leak. When not, there's no leak.
« Reply #9 on: September 18, 2019, 12:52:43 AM »
use soapy water.
Offline pjlogue
« Reply #10 on: September 18, 2019, 08:44:19 AM »
In checking, the reference to boot leak and running rich is on page IV-12 or IV-13.  He did not give the physics of why a leak causes a rich condition in the 1500-3500 RPM range.  It may be because these are pulse induction carbs as opposed to constant vacuum.
-P.
Offline maxheadflow
« Reply #11 on: September 18, 2019, 06:23:06 PM »
Couple things.  It's not an air screw, it's fuel.   On the cylinder that is rich, try turning in the mixture screw 1/2 turn.
Its possible that someone opened up the pilot jet when cleaning it out.
Offline cwchan
« Reply #12 on: September 18, 2019, 08:45:07 PM »
-P.
Confirmed. There is a leak on #2 and to a lesser extent #4.  Both between the intake manifold and the cylinder head.
1-4 left to right. You can see 4 is the next richest
Thanks. I’ll see how the spark plugs read after sorting out the leaks
« Last Edit: September 18, 2019, 10:22:58 PM by cwchan »
Offline Deltarider
« Reply #13 on: September 18, 2019, 10:41:19 PM »
How did you come to the conclusion there are leaks?
Offline pjlogue
« Reply #14 on: September 19, 2019, 05:07:20 AM »
-P.
As Deltarider asked; how did you determine the leak?  If it was from spraying carb cleaner on the boots while the engine was idling read on.
If your boots are cracked I would replace them.  If it is a matter of the rubber being very stiff you can heat them with a hairdryer and tighten down on the clamps.  If the clamps are stretched like mine were so there was no more thread to tighten you can glue a 1/16" thick strip of gasket material to the inside of the clamp to give more compression to the boot.
I tried softening the boots with wintergreen oil and a carrier.  They softened all right and also swelled.  I would consider this if I was desperate and in a bind.  Not a long term solution in my mind.
-P.
Offline cwchan
« Reply #15 on: September 19, 2019, 09:18:59 AM »
I used the carb cleaner method.  I used the straw thing to spray in specific spots this time.
Its not the boots that are leaking though.  Its where the intake manifold meets the cylinder head.  I know there are some o-rings that are in there.  I remember replacing them but maybe i didn't tighten it enough.  I have some spare o-rings if tightening the intake manifolds doesn't work.
Thanks again
« Reply #16 on: September 19, 2019, 03:50:55 PM »
I have replaced these orings on another bike I have and when I pulled the carbs and motor for some other work I discovered the orient had slipped and was partially cut but still sealing.  When they get old they grow hard and are almost like plastic, they can get that hard and brittle.  Change out the orings and see if your plug fouling lessens or goes away.
Looks like you have it running pretty rich.
When did you last clean your air filter or replace it?
Have you checked the ohms of your spark plug caps? They should be around 5k ohms each.
Weak spark can contribute to rich running too...
Offline cwchan
« Reply #17 on: May 14, 2020, 03:57:56 PM »
Hi again,
I replaced the O-rings between the cylinder head and the intake runners, changed the main jets from 95’s to 90’s. Producing this result
I had the engine running and warmed up and sprayed a whole can of carb cleaner all over ... no drops in rpm.
At this point it runs well.. in thinking I should accept the difference in plug appearance and just enjoy the ride.
What do you alll think?
« Reply #18 on: May 14, 2020, 04:31:35 PM »
It looks like you're getting it real close!
Try this: switch to lower octane fuel, like Regular and not higher grade. All gasolines today burn much slower than they did in the 1970s, and many of them have ethanol added as well - which burns slower yet. Less octane will help lighten up the plugs, and on the 550 also improves the low-end torque a bit. It can be made even better by delaying the spark advance, but this will be tough work if you have a Dyna that is currently tuned: you'll have to re-tune it again afterward. To slow the advance, cut off at least 1/2 turn of one of the spark advancer's springs and rebend the end back to nab the weight again (leave the post end alone so it still fits on the post)...
This will both perk up the low-end torque and lighten the plugs. The stock mainjet will be either the Kehin #95 or the Keyster #100, all else being equal. The Keyster jets feed about 7% less fuel than the Keihins for the same jet-size number.
Offline cwchan
« Reply #20 on: May 16, 2020, 07:24:36 PM »
Thanks I’ll try this. I have been running premium because I read somewhere that the quality of fuel in reg is poorer, so they add ethanol to boost the octane rating.
Offline cwchan
« Reply #21 on: May 16, 2020, 07:26:22 PM »
Does it run smoothly?
Yes it does run smoothly.. the odd #2 plug just bothers me... thinking it might not be a problem now.. but will be in a few thousand km
« Reply #22 on: May 16, 2020, 10:39:03 PM »
Lower octane gave plugs a lighter color?
Offline DaveBarbier
« Reply #23 on: May 17, 2020, 05:01:48 AM »
All octane ratings at the pump have the same amount of ethanol. Here in CT it’s around 10%. There are many additives that increase octane, not just ethanol.
Small rant alert: Not true about the fuel. Quality of the fuel is the same. Higher octane fuel only helps prevent preignition. The reason that people think it’s better is because the oil companies see that people feel better about paying more for fuel because they think it’s better, so they end up marketing it that way. Higher number is better than lower number, right? A Ferrari would use it so my Corolla should too. Adding octane is a cheap way for Mobil, Shell, etc. to make more money - dilute the actual gasoline with an octane booster and sell it for a higher price. The reason high performance vehicles (and many newer vehicles) use high octane fuel is because the compression of the engines are so high. Higher compression gives more power for the same engine size, but compressing the fuel so much makes it ignite prematurely in the combustion chamber. Adding octane prevents that. So essentially it’s a fuel that’s harder to ignite. Theoretically you might get more power with a lower octane fuel because it is more inclined to ignite. It doesn’t really work that way in practice though. The best thing to do is use what fuel it says in the owners manual unless the engine has been modified. It’s also cheaper so you’ve been wasting money.
This is a good video.
