Author Topic: Spoke kit problem...  (Read 1573 times)
Offline DME
« on: September 23, 2019, 02:27:51 AM »
Just started lacing up a CB750 front wheel and immediately ran into an issue with the inner spokes.
The bend is too short and will not allow the inner spokes to meet up with the holes in the rim unless considerable sideways tension/bend is put on them.
The spoke kit is from David Silver Spares and I have contacted them to hear if they have run into this issue before.
The outer spokes in the kit are fine.
I used their kit for the rear wheel also, and it laced up just fine.
So my question is if anyone over here has had the same problem with their kit, and if so what the solution/explanation was?
Here's a couple of pics, the last one shows a comparison of the spoke angle of a kit spoke and a stock spoke...
« Last Edit: September 23, 2019, 02:31:11 AM by DME »
Offline jgger
Re: Spoke kit problem...
« Reply #1 on: September 23, 2019, 07:05:03 AM »
Did you try the offending spokes the other way (using them as an outer) , just to see how they fit?
Offline DME
« Reply #2 on: September 23, 2019, 07:39:37 AM »
The outer spokes are fine, and they fit perfectly the way they should.
Fitting inner spokes as outers is not even close to working.
Offline DME
« Reply #3 on: September 23, 2019, 12:47:24 PM »
A touchup with the die grinder took care of the clearance issue.
It should not be necessery but it solved the problem.
Moving on...
Offline Korven
« Reply #4 on: December 14, 2019, 03:03:00 PM »
Those are the same spokes i have a problem with. The outer spokes have a too big bend and doesnt seat properly. did you mail David S?
http://forums.sohc4.net/index.php/topic,180290.0.html
Offline DME
« Reply #5 on: December 18, 2019, 07:17:28 AM »
Yes, I e-mailed them and got the usual answer "We have sold lots of these kits and never heard anyone complain before".
In my kit the problem wasnt the outer spokes, it was the inners that had a slightly too short bent part.
That gave rise to the problem seen in the pics above.
Since they didnt ackowledge the problem, and the purchase was done over a year earlier, I decided to push on and solved the problem by grinding away 0.5mm on the inside of the hub where the inner spoke and the hub interfered.
Should not be needed, but like I said I needed to push on...
Offline the-chauffeur
« Reply #6 on: December 18, 2019, 01:55:19 PM »
I'm assuming you've seen this post . . .
