The crankshaft oil seal is a fraction further out at the bottom than the top. I made sure the seal was seated correctly in the bottom half before mating the cases, but did not check the top (a million things to check and trying to work quickly. The seal was seated correctly in the small notch in the bottom. I think it’s fine, but thought I would check with you guys.
The cam chain got wedged between the primary chain tensioner and the case. I was very gentle with the tensioner, but did apply slight pressure to get the cam chain free. Again probably fine, but wanted to see what you guys thought.
