Author Topic: '71 CB750 K2 dying while riding  (Read 908 times)
Offline sullivad1618
« on: October 03, 2019, 09:02:04 AM »
Need some ideas folks. Riding home on my 1971 k2 today when it died. Took a couple minutes of trying but it started again, only to die again a few minutes later. This happened twice more, every time it would take a couple mi utes of trying before it would start. the last time when coasting to a stop I tried giving it a little gas, and it started again, but was herky jerky like fuel was intermittent. First time it happened was while clutch was pulled in, downshifting to stop at a light. Other times were while cruising along at between 40 and 50. Any ideas on where to start? I have a brand new petcock, new plugs, did the timing and synced the carbs about two months ago.
Sent from my SM-G960U using Tapatalk
Offline Pielz
Re: '71 CB750 K2 dying while riding
« Reply #1 on: October 03, 2019, 09:09:52 AM »
If it's dying like it's running out of gas, it could be that the tank is getting a vacuum and the gas isn't able to flow? I've been having issues with that but on my k7. Petcock on, but it spitters and dies. I just have to crack the gas cap and then tighten it again.
Sent from my LG-G710 using Tapatalk
Offline Pielz
« Reply #2 on: October 03, 2019, 09:15:12 AM »
Yeah that's a good point. Being gravity fed, the fuel lines shouldn't be travelling uphill at any point.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: October 03, 2019, 10:01:59 AM »
Fuel cap vent blocked? Do you have inline fuel filters?
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: October 03, 2019, 10:30:33 AM »
Checked the petcock screen/ filter is clean and clear?
« Reply #5 on: October 03, 2019, 10:56:34 AM »
+3 on fuel cap vent. I had a tank with rusty blocked vent. Bike ran well for almost 10 minutes, then starvation.  Open fuel cap and see if it start when it dies
« Reply #6 on: October 03, 2019, 11:46:13 AM »
 Just out of curiosity how long have you been riding the bike and it seems this is an issue that has just recently cropped up ? Make sure you check the temperatures with a wet rag or something of the exhaust headpipes the next time it fizzles out to make sure you are hitting on all 4 and if not you can isolate which ones may not be as hot as the others. That could lead to help in more troubleshooting like a set of points crapping out or one bad carb,which carb or other carbs not getting fuel, etc. etc..
  On a side note a K2 750 is a 1972 and a 1971 is a K1.
« Last Edit: October 03, 2019, 04:32:50 PM by ekpent »
Offline Menno
  • www.tanklackieren.de
« Reply #7 on: October 03, 2019, 01:23:18 PM »
Maxbe try this:
Start your bike.
Let it idle.
Pul the negative wire from your battery.
If your bike stalls it is not charging properly.
« Reply #8 on: October 04, 2019, 05:26:05 AM »
Its been running fine for a while, about 3 months with no issues. Good idea, thanks for the advice. It is a 71 k2, they started making k2 november of 71.
Offline Maraakate
« Reply #9 on: October 13, 2019, 06:34:23 PM »
It may be the condensor.  Some times they get will read out okay on a tester but once they are heated up (after 5-10 minutes of solid riding) then they cut out and cause issues.
1977 CB550K
1979 CM400A
