Author Topic: Diff between cb550K and CB550F  (Read 12524 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: February 02, 2007, 08:13:57 PM »
I know, this is a real noob question, but despite google research, I haven't been able to learn this on my own.
What is the difference between the F and K model CB550? I know from a carb thread that there is a difference in that department. Aside from that?
Is the F the supersport designation?
1978 CB750K8; 1970 CB450
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: Diff between cb550K and CB550F
« Reply #1 on: February 02, 2007, 08:25:17 PM »
Yes, the F is the Supersport model.  K has 4-4 exhaust, F 4-1 exhaust.  K has the standard flip-top gas tank, F has the concealed version.  Seat & tank dimensions are slightly different.  There's some body differences, mostly from the exhaust: footpegs & kicker are slightly different.  Side panels are different with the F a smaller, more triangular style.  They're more or less the same bike, but not everything is a direct swap.  Search the forum for a more detailed list, I know its on here somewhere.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline 78 k550
« Reply #2 on: February 02, 2007, 08:28:09 PM »
the F also had a 37 tooth rear not 34 like the K. Side covers are different. The seat is tappered up more in the rear on the F than the K and the grab bar follows. Foot pegs are different and also the kick starter. the headers are different. Like said also the carbs. and intakes.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #3 on: February 02, 2007, 10:05:04 PM »
Sorry, not true.  All the 550s F or K had 37 tooth rear sprockets.  The 34 tooth rear sprockets were found on the Cb500s.
 Only the 77 and 78 K models had different intakes to match the PD carbs found on those models.
All three years of the F (75-77_ used the same Keihin carb types as the 71-76 CB500/550,  However, there were different internal parts and setups for the Cb500, Cb550K, and CB550F.
Surprisingly little interchanges between F and K models, beside the engine unit proper, the front end w/ brakes, lighting fixtures, and most electrical components.
The super sport is the F model.
Offline jabbadeznuts
« Reply #4 on: February 02, 2007, 11:31:47 PM »
True. 37 tooth rear sprocket.
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
Offline Deltarider
« Reply #5 on: February 03, 2007, 12:18:41 AM »
Correction. According to p62 partslist HONDA CB500K3/CB550K3/CB550K4 the CB550K3 ED had 34T.
CB500K2-ED Excel black
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #6 on: February 03, 2007, 06:22:33 AM »
Interesting, I have a 550F motor in my 71' 500, now you have me thinking about that 37T sproket.....
I assume the fronts were the same?
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #7 on: February 03, 2007, 09:16:21 AM »
According to the Shop Manuals all `71-`73 CB500s have 17t front and 34t rear sprockets & all `74-`78 CB550s have 17t front and 37t rear sprockets. The reason being that the transmissions final primary reduction went from 2.000 in the 500 to 3.063 in the 550 models.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Deltarider
« Reply #8 on: February 03, 2007, 10:13:14 AM »
Again. The CB550K3 ED (Europe Direct Sales) has 34T.
« Reply #9 on: February 03, 2007, 10:27:58 AM »
I think the chances of gregwaits encountering a 34T Cb550 in North Texas (beautiful as it is) are pretty small then, don't you think?
Who are you trying to help?  And, why aren't you using the :P ?
Offline Deltarider
« Reply #10 on: February 03, 2007, 01:54:14 PM »
TwoTired,
There are a lot of manuals around that give inaccurate information (the Haynes in particular). If European 550K3 owners read in this forum that [all/i] 550's have the 37T sprocket (as stated above), they might think: hey, I've got the wrong one. Those are the people I'm trying to help with the correct information. I've seen no 550K3's with the 37Tsprocket.
