Author Topic: Carb Drain Plugs  (Read 1502 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
Carb Drain Plugs
« on: October 11, 2019, 08:27:06 AM »
Does anyone know if the carb drain plugs on the CB400F (054A) are the same as on early 750Ks? (Can’t remember the model)
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline Pielz
Re: Carb Drain Plugs
« Reply #1 on: October 11, 2019, 08:35:14 AM »
The 75-77 400F looks to be the same as the 69-76 750k and f drain screws.
Sent from my LG-G710 using Tapatalk
Offline Bodi
« Reply #2 on: October 12, 2019, 04:37:42 AM »
The 400 ones have a very fine pitch thread, sorry I don't have the spec but it's not found at typical hardware stores that do stock metric. And the 400 ones drain fuel through the middle of the screw, some other carbs use the screw as a valve and drain from the overflow... these types will not interchange very well.
Offline ADW
« Reply #4 on: October 15, 2019, 09:48:16 AM »
