Author Topic: cb400f countershaft drive side bearing removal - how?  (Read 1424 times)
Offline awrawr
« on: October 17, 2019, 01:09:36 PM »
I am having trouble getting the bearing race off the drive side of the output shaft on my cb400f.
The plain spacer (collar) on the outer side of the shaft (which fits in to the the output oil seal) just will not budge off the splines.
Are there any tricks to this?
Thanks
« Last Edit: October 17, 2019, 01:53:55 PM by awrawr »
Offline BenelliSEI
  • 1969 cb750
Re: cb400f countershaft drive side bearing removal - how?
« Reply #1 on: October 17, 2019, 04:33:27 PM »
Photo would help.
Offline awrawr
« Reply #2 on: October 18, 2019, 12:11:30 AM »
The splines end of the shaft next to the collar is where the final drive sprocket fits.
I tried a little heat. Still no joy. As this end of the shaft pokes out of the crankcase, I'm guessing that 35 years in the shed has allowed the collar and the splines to corrode together?
I'm sure I've changed this bearing on another 400/4 a long time ago without any trouble. (Maybe I've just got weaker in tha arms)
Offline awrawr
SOLVED - cb400f countershaft drive side bearing removal - how?
« Reply #3 on: October 18, 2019, 10:50:50 AM »
Solved - strip all the gears off the other side, support the shaft, output side pointing upwards, with two end-on pieces of 4×2 (equal length), apply lots of heat to the collar and belt the shaft with a hammer, with a bit of wood between it and the shaft end to a void denting it. Presto.....
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #4 on: October 21, 2019, 07:26:25 AM »
You should have used a press to remove the bush, it's a press fit.
with the heat you probably melted the O-ring so replace that (they are normally hard anyway).
Re install with a press.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline awrawr
« Reply #5 on: October 21, 2019, 10:02:51 AM »
Which o ring? Theres no sign of any residue in the collar?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=7k1rqt3j9qu663vp7mh15mfba2&/topic,60973.0.html
« Reply #6 on: October 21, 2019, 11:37:56 AM »
is it hard to fint the bearing vith the grove...as i renember its not in the spareparts..as a parts number...so had to be faund as a extern part..
i hate all this v-w.... vords
Offline awrawr
« Reply #7 on: October 21, 2019, 12:03:16 PM »
Ah.... there is a hard dark ring on the shaft just behind the splines which could have once been an o ring. Looks more like a plastic washer. Probably obably the heat did that then.
Does anybody have the dimensions for this o ring please? And suggestions as to composition? Nitrile? Silicone rubber? Viton? Etc.
Pressing would've been preferable, but I don't have access to one. I also have a spare set of shafts in a spare engine. I fear the knowledge that I have that as a plan 'c' leads me to the risky option too readily.
