Author Topic: 1974 CB550 Valve Cover Issue  (Read 3033 times)
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« on: October 23, 2019, 02:38:20 PM »
Is there a ballpark mileage figure for when I can expect to start having problems adjusting the valves on this bike?  Currently has 23000 and no sign of a problem.
Cheers - Dennis
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 1974 CB550 Valve Cover Issue
« Reply #1 on: October 23, 2019, 05:07:38 PM »
The 550 rockerbox wear problem depends on the usage more than the mileage.
Quality oil and a gentle right hand will extend the life the rocker shaft bores.
Redlining it and reticent oil changes, could see conditions deteriorate rather quick like.
The lowest effort preventative measure discussed has been to squish a few o-rings between the inspection cap holes and the rocker shaft ends.
The Honda solution was to pin a full length rocker arm shaft in place.  The 77 update.  Unfortunately the available rocker arm shaft part from 77 does not fit into the valve covers of previous the generation.
To secure the multitude of rocker arm shafts in the early model rockerbox would require a bit of time at the milling machine and drill press.
Repairing worn rockerboxes may be more trouble than it's worth.
« Reply #2 on: October 25, 2019, 04:46:12 AM »
Thanks BomberMann.  Is the o-ring fix worth the effort, or is it better to just replace with a '77-'78 cover?
Cheers - Dennis
Offline flatlander
« Reply #3 on: October 25, 2019, 05:13:29 AM »
if your cover is not yet worn, then definitely it's worth the effort. especially because the effort and cost is almost 0.
« Reply #4 on: October 25, 2019, 01:03:25 PM »
Is there a thread on here about the o-ring procedure?  Size of o-rings, inspection cap removal, etc?
Thanks again - Dennis
Offline flatlander
« Reply #5 on: October 26, 2019, 12:20:47 AM »
use the same o-rings as on the end cap, no. 20 in the diagram.
you just take off the end cap itself, insert 4 additional o-rings in the holes where the rocker shafts are, then put the end cap back on. done.
« Reply #6 on: October 27, 2019, 08:00:57 AM »
Perfect!  Thank you flatlander.  =;-)
Cheers - Dennis
Offline flatlander
« Reply #7 on: October 28, 2019, 02:08:02 AM »
just re-read that and realise it could be misunderstood. you need 4 o-rings total, and put 1 in each hole. not 4 per hole ;)
« Reply #8 on: November 07, 2019, 11:44:27 AM »
Okay, so I just broke down and purchased a late model rocker cover.  It looks like the seller removed the nuts on the studs holding the rocker shafts in place.....
Do these have washers under them?  Looking at a parts diagram, it looks like the diagram shows bolts and not nuts and washers???
Dennis
Offline jakec
« Reply #9 on: November 07, 2019, 12:05:24 PM »
So you're just doubling up all the O rings?
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
« Reply #10 on: November 07, 2019, 01:33:47 PM »
Wrong parts diagram, you need to look at the one with rockers shafts and arms for the 77 550 or the technical bulletin in the manals section
« Reply #11 on: November 07, 2019, 02:10:33 PM »
Thanks Bryan, it was in the bulletin.
Cheers - Dennis
Offline Erny
« Reply #12 on: November 08, 2019, 01:56:00 AM »
I'm thinking about the same "retrofit" in the future.
There are quite some on ebay etc but I don't know how it should look like to avoid purchasing old version.
Can someone post photo how new improved version of cyl head cover looks like?
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline middletons
« Reply #13 on: November 08, 2019, 07:23:02 AM »
A good picture is already posted above (reply #8). The newer rocker cover has 8 bolt holes in the middle section instead of 4.
« Last Edit: November 08, 2019, 07:26:04 AM by middletons »
« Reply #14 on: November 08, 2019, 08:48:32 AM »
New style...
Old style...
Cheers - Dennis
« Reply #15 on: November 08, 2019, 09:32:27 AM »
You have a 550?
Offline Erny
« Reply #16 on: November 08, 2019, 12:12:52 PM »
Yes I have 550K1 model year 1975, built 10/1974. By engine number I shall have old style cover. Engine has never been opened... But I'll check before buying. The point is that I hear ticking noise from top (valves are set correctly), so suspect shaft/cover wear
This one
« Last Edit: November 08, 2019, 12:14:44 PM by Erny »
« Reply #17 on: November 08, 2019, 02:16:53 PM »
Before you comdem the valve cover check the exhaust gaskets as a slight blow sounds exactly like a loose tappet,  believe me i have the tee shirt AND video for that one (not literaly before somebody asks for a copy!)
« Reply #18 on: November 08, 2019, 04:47:52 PM »
This one
Very nice!
